This topic contains 22 replies, has 3 voices.
Last updated by sarah.n 6 years, 11 months ago.
Assigned support staff: sarah.n.
December 4, 2014 at 2:31 pm #523168
Timothy
I am trying to: I am trying to have users to fill in a form to create a new posting. Then this post will be duplicated to different languages I have.
I visited this URL:
I expected to see: Afterwards I expected that the post will be duplicated however, I get a blank page afterwards and seems like the make_duplicate class is not found. This was working before but unfortunately it does not work anymore.
Instead, I got: Blank screen and if i turn debug testing on I see the following:
Fatal error: Call to undefined method stdClass::make_duplicate() in /var/www/vhosts/domain.com/httpdocs/wp-content/themes/theme_name/functions.php on line 3768
December 4, 2014 at 3:41 pm #523234
Timothy
By the way I have declared the lib with the following:
global $iclTranslationManagement, $sitepress, $ICL_Pro_Translation;
	if ( !isset( $iclTranslationManagement ) ) {
        if(!class_exists('TranslationManagement')){
            include(ABSPATH.'wp-content/plugins/sitepress-multilingual-cms/inc/translation-management/translation-management.class.php');
            include(ABSPATH.'wp-content/plugins/sitepress-multilingual-cms/inc/translation-management/pro-translation.class.php');
        $iclTranslationManagement = new TranslationManagement;
        $ICL_Pro_Translation      = new ICL_Pro_Translation();
December 5, 2014 at 7:56 am #523564
Andreas Neuber
Sorry for the "undefined" trouble!
I remember this problem from some other similar tickets. Looks as if we should update our documentation a bit. Will talk to our team about it.
In order to find a solution for your challenge, could you please try this as test?
1) Copy this code http://pastebin.com/bVNkYQXW into your themes "functions.php" file
2) Create a new post under "Posts > Add new"
3) Now, please check - was this post duplicated in all your languages?
If so, very good, then we need to adjust this further to fit your user form.
December 5, 2014 at 10:44 am #523702
Timothy
Yes this worked actually.
Do you know how what I can change to fix the custom post type and duplicate the posts?
December 5, 2014 at 10:58 am #523721
Timothy
In addition, this is for a custom post type I have created:
function create_post_type() {
  register_post_type( 'listings',
    array(
      'labels' => array(
        'name' => __( 'Listings' ),
        'singular_name' => __( 'Listing' )
    'public' => true,
    'has_archive' => true,
	'rewrite' => array('slug' => 'listing'),
December 5, 2014 at 1:40 pm #523869
Andreas Neuber
Happy to hear.
Here 1 more listing, very similar: http://pastebin.com/bZE820Ja
# Now when you look at line 26:
$sitepress->is_translated_post_type( $post_type )
This code checks if the post type is a "translatable" one.
The standard WP post is always translatable. But a new custom post type like your "listings" needs to be set to "Translate". This you can do under "WPML > Translation Management > Multilingual Content Setup > Custom Posts".
in_array( $post_type, $only_cpt )
This code makes sure that the duplication only happens with specific custom post types. So in line 5 you need to replace "book" with "listings".
# Could you adjust the code and run one more test?
This time again in the backend but use "Listings > Add new".
Again - is the new listing automatically duplicated in all languages?
December 5, 2014 at 5:15 pm #524000
Timothy
Hi Andreas,
I tried the following added the following to the function.php within theme.
function duplicate_master_post($post_id, $post, $update){
    global $sitepress, $iclTranslationManagement;
	$only_cpt 	= array();
	$only_cpt[] = 'listings';
    if ( defined( 'DOING_AUTOSAVE' ) && DOING_AUTOSAVE ) {
        return;
    // don't save for revisions
    if ( isset( $post->post_type ) && $post->post_type == 'revision' ) {
        return;
    // only duplicate when publishing
    if ($post->post_status != 'publish') {
        return;
    // avoid recursion
    remove_action('wp_insert_post', 'duplicate_master_post', 10);
    $post_type = get_post_type( $post_id );
    if ( $sitepress->is_translated_post_type( $post_type ) && in_array( $post_type, $only_cpt ) ) {
        $iclTranslationManagement->make_duplicates_all( $post_id );
add_action('wp_insert_post', 'duplicate_master_post', 10, 3);
Afterwards in one of the page I tried the following:
$posts_array = get_post( 595 );
duplicate_master_post(595, $posts_array, null);
However, when the page loads it breaks.
December 5, 2014 at 5:17 pm #524001
Timothy
It is still at the problem:
December 6, 2014 at 6:37 pm #524274
Timothy
Is there any solution for this or can I give you the access information to have a look at it. Seems like we going through loops with the problem of the class rather than getting a solution.
December 8, 2014 at 12:26 pm #524756
Andreas Neuber
Sorry for the delay!
# Regarding https://wpml.org/forums/topic/make-duplicates-of-a-post-does-not-work/#post-524000
You should not need an extra:
Line "add_action('wp_insert_post', 'duplicate_master_post', 10, 3);" ensure that the function "fires" when a post is created.
# Yes - credentials for your website would be good
I'm quite interested to get this going. We need some working code for this API function.
You should see a protected webform all they way down here in this thread. (it asks first for "Backup + Legal disclaimer")
Thanks in advance!
December 8, 2014 at 1:26 pm #524841
Timothy
Hi Andreas,
I am still unsure what you mean by add_action('wp_insert_post', 'duplicate_master_post', 10, 3);
I currently have a shortcode that would create a new listing:
$post = array(
						'post_content' => '',
						'post_title' => $_POST['pacadddress'],
						'post_status' => 'pending',
						'post_type' => 'listings'
					$post_id = wp_insert_post( $post );
It then returns the new post_id in which it will create different language's translation.
Before it worked when I did the following but now it doesn't work now.
if($sl != 'en')
						echo 'en';
						$new_lang_id[] = $iclTranslationManagement->make_duplicate($post_id, 'en');
					if($sl != 'zh-hans')
						echo 'zh-hans';
						$new_lang_id[] = $iclTranslationManagement->make_duplicate($post_id, 'zh-hans');
					if($sl != 'zh-hant')
						echo 'zh-hant';
						$new_lang_id[] = $iclTranslationManagement->make_duplicate($post_id, 'zh-hant');
Do you have an email address where I can send you the login information for you to help me have a look as we are ready to alunch the website but the only thing that is not working is this problem.
December 8, 2014 at 5:15 pm #524987
Timothy
Hi Andreas,
I totally understand now the line:
when the custom posts creates it will fire the code.
but the problem is as follows:
echo 'same problem';
echo ' here';
I have attached the screenshot of when I want to create the custom post:
I have set before it goes into the make_duplicates_all to echo "Same Problem" then afterwards to post here. So it never reached "Here"...
December 9, 2014 at 5:59 am #525181
Andreas Neuber
Thanks - 2 questions:
1) Credentials
https://wpml.org/forums/topic/make-duplicates-of-a-post-does-not-work/#post-524756
I mentioned here clearly that there is a protected webform for you to enter credentials.
Was the form not visible? (hope we dont have JS problem there).
I displayed the form for you again - you should see it below my reply here.
Please use it, because thats really the only way to involve other supporters & developers as well.
2) Thanks for code snippet here: https://wpml.org/forums/topic/make-duplicates-of-a-post-does-not-work/#post-524987
What is the location of this file?
Is it the "functions.php" of your theme?
December 9, 2014 at 6:15 am #525183
Timothy
Thank you very much. It was really weird I did not see the web form until now. Anyways I have supplied the information and sent the webform. Really appreciate your help. Hoping can have this resolved.
December 9, 2014 at 7:04 am #525190
Andreas Neuber
Thanks a lot!
# WP admin access works - FTP password not. Might be just a small typo.
Could you check this for me?
# Why did this part of the code not work?
echo ' here';
You see this condition
Duplicates are only created of the "listings" post type is "translatable".
As mentioned further up you need to make your new "listings" translatable - manually.
This needs to be done under "WPML > Translation Management > Multilingual Content Setup > Custom Posts". Please set it to "Translate".
