Last updated by Jamal 11 months, 3 weeks ago.
June 10, 2019 at 10:58 am #3986959
alexisM-2
In admin side, i've got this message :
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Max connect timeout reached while reaching hostgroup 0 after 10000ms
Array
[language] => en
[context] => WooCommerce Endpoints
[gettext_context] =>
[domain_name_context_md5] => 805eb3cc295a715c3b054c43d99bff17
[name] => order-received
[value] => order-received
[status] => 0
[translation_priority] => optional
[allow_empty_value] =>
Thanks for your help !
Below my debug access ...:
PHP
Version 7.0.33
Limite de mémoire 512M
Utilisation de la mémoire 98.89 MB
Temps d'exécution max. 300
Max input vars 16000
Jeu de caractères Utf8mb4 Oui
Extension de chaîne multioctet Chargée
Extension SimpleXML Chargée
WordPress
Version 5.2.1
Multisite Non
Limite de mémoire 256M
Limite de mémoire max. 512M
June 10, 2019 at 11:20 am #3987077
Jamal
Timezone: Africa/Casablanca (GMT+00:00)
This notice is usually a false positive. You can just dismiss it and it won't return again. If it does, we will need a copy of your website using the Duplicator plugin so we can investigate this issue further.
Can you please paste your WPML Debug information in the Debug information field?
- http://wpml.org/faq/provide-debug-information-faster-support/
Jamal
WPML Support
