Show one menu for not-logged in users and a different menu for logged in users.
function display_correct_menu($args = '') {
       if ( !is_user_logged_in() ) { $args['menu'] = wp_get_nav_menu_object( 'menu-not-logged-in' ); }
     else { $args['menu'] = wp_get_nav_menu_object( 'menu-logged-in' ); }
         return $args;
add_filter( 'wp_nav_menu_args', 'display_correct_menu' );
Last updated by Otto 2 years, 12 months ago.
Assigned support staff: Otto.
January 22, 2017 at 11:50 pm #1187815
edwardS-6
I am trying to: Show one menu for not-logged in users and a different menu for logged in users.
When using code like this in my functions.php, the WPML language switcher disappears from the menu:
if ( !is_user_logged_in() ) {$args['menu'] = 'top-not-logged-in';} else {$args['menu'] = 'top';}
return $args;
I assume the problem is because the same filter is being used by WPML in the file: class-wpml-nav-menu.php.
Is there a way to accomplish what I need without changing WPML code?
URL of (my) website where problem appears: hidden link (but you really don't need to visit it)
Thank you very much!
January 23, 2017 at 12:24 pm #1188266
Otto
Thank you for contacting the WPML support!
Did you add a language switcher to each menu (top-not-logged-in and top)? You can add them here WPML > Languages > Language Switcher Options > Menu language switcher
Let me know if that helped, please.
Kind Regards,
Otto
January 23, 2017 at 2:28 pm #1188416
edwardS-6
Both menus show the language switcher when I comment out this code in my functions.php:
The problem appears to be that this filter is also being used by WPML.
I need to show different menus for logged in and not logged in users.
January 23, 2017 at 5:23 pm #1188626
Otto
Thanks for the explanation.
The problem seems to be that 'menu' is a term object and the filter is replacing it with a 'string'.
Please try this instead:
$args['menu'] = wp_get_nav_menu_object( 'top-not-logged-in' );
And the same with 'top'
I tried it locally and it worked fine.
Kind Regards,
Otto
January 23, 2017 at 9:55 pm #1188798
edwardS-6
This is our solution, thank you so much for the help!
       if ( !is_user_logged_in() ) { $args['menu'] = wp_get_nav_menu_object( 'top-not-logged-in' ); }
     else { $args['menu'] = wp_get_nav_menu_object( 'top' ); }
         return $args;
Solved! GREAT! Comments?
January 24, 2017 at 1:54 pm #1189395
Otto
Nice! I'm glad it helped 🙂
Kind Regards,
Otto
