Last updated by patrickS-52 10 months, 1 week ago.
July 25, 2019 at 5:48 pm
patrickS-52
Site is in English ( default language ) and in French ....The menu on French side is now in English...I cannot change it anymore....I updated all plugins and made sure that all WP parameters and PHP ini files for WPML are set correctly.....using PHP 7.1 edge
July 25, 2019 at 7:03 pm #4285639
Bigul
Welcome to the WPML support forum. I will do my best to help you to resolve these issues.
Please try the following steps after a backup and make sure you are getting the expected result or not.
1) Visit WPML>>String Translation
2) Click on the blue link at the bottom of the page: "Translate texts in admin screens »"
3) Look for the *theme_mods_child* option. Here you should find all the strings associated with your theme options.
4) Check the checkbox for the menu options.
5) Click on the button "Apply"(at the bottom of the page)
6) Now, all your selected strings should appear in the String Translation panel
7) Translate it with French Menu ID
Please check the following documentation for more details.
https://wpml.org/documentation/getting-started-guide/translating-theme-options/
https://wpml.org/documentation/getting-started-guide/string-translation/#admin_texts
Bigul
July 25, 2019 at 8:07 pm #4285823
patrickS-52
