Last updated by Diego Pereira 1 year ago.
Assigned support staff: Diego Pereira.
May 8, 2019 at 2:49 pm #3767909
laurentW-2
We are trying to translate our product pages from french to spanish
We just try with this french product page : hidden link
To spanish : hidden link
We do not have same blocks and same contents in the editor to make a complete traduction of all the good fields in french.
Can you help us to resolve it?
Regards
May 8, 2019 at 7:08 pm #3770339
Diego Pereira
Hello @laurentw-2, welcome to the WPML support Forum!
Probably your theme or some plugin is generating elements that are not registered for translation in wpml-config.xml. In this case it may be necessary to register these elements: https://wpml.org/documentation/support/language-configuration-files/
Could you please provide your debug information so that I can get a look at some of your configurations. We have an excellent article on how to located here: https://wpml.org/faq/provide-debug-information-faster-support/.
NOTE: Please be sure to check the box to indicate you can provide debug info and paste your debug info in the debug field provided, and NOT in the general response field.
Another option is to translate using the manual editor:
- Go to the edit screen of the page (original language).
- Turn off the "Use WPML's Translation Editor" on the right sidebar
- Select your editor preferences and save
- Edit the translation
Please let me know if it worked for you.
All the best,
Diego
May 9, 2019 at 7:29 am #3773695
laurentW-2
Hi Diego,
First thanks for your quick answer, here has you ask me I send you our debug information
Regards
May 9, 2019 at 6:51 pm #3778903
Diego Pereira
Thanks. I noticed that you are using the first pixel theme, which is not at our compatible themes list: https://wpml.org/documentation/theme-compatibility - the theme may be adding extra elements that are not registered for translation.
I sent some instructions to replicate the website through a private message (previous answer).
Please let me know if it worked for you. If so, please send us clear instructions on how to see/reproduce the issue.
Kind regards,
Diego
The topic ‘[Closed] Missing parts of text fields’ is closed to new replies.
