Last updated by pawelZ-10 10 months, 3 weeks ago.
Assigned support staff: Dennis.
July 6, 2019 at 7:58 am #4155283
pawelZ-10
I am trying to:see different prices beetween PLN and EUR, and only currency symbol change
Link to a page where the issue can be seen:hidden link
I expected to see:different price in EUR than PLN
Instead, I got:same amount of each currency
July 8, 2019 at 2:09 am #4158387
Dennis
Welcome to WPML Support forum.
I noticed that you're outdated versions of WPML plugins. Please consider updating WPML plugins to latest versions and check if the issue is resolved.
You can update WPML plugins at Plugins > Add new > Commercial tab.
Note: Please backup your site completely before updating WPML.
If the issue still persists after updating your plugins, please check if this issue appears when:
-You deactivate all non-WPML plugins, except the plugins required to debug.
- Theme is set to a WordPress default like Twenty Sixteen. Its will tell us if there is an interaction issue with your theme.
- If the problem disappears, start activating one at the time to track where the incompatibility is produced.
Note: Please backup your site completely before doing this test.
Please let me know your results.
Kind regards,
Dennis
July 8, 2019 at 6:53 am #4159369
pawelZ-10
Weird, because I just added new product hidden link ind it is working OK with currencies
July 8, 2019 at 7:32 am #4159583
pawelZ-10
I think the issue is connected with product attributes, when they are used, currencies working ok, when I setup product as simple product, price doesnt change.
July 8, 2019 at 8:28 am #4159981
Dennis
Thank you for your updates.
Could you please confirm that this issue still occurs after updating WPML plugins and putting your site on a minimum environment? (deactivating non-WPML plugins and switch theme to one of WP default themes)
If yes, I would like to request temporary access (/wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. Your next reply will be set to private.
Maybe I'll need to replicate your site locally to continue debugging and escalate if necessary. For this I’ll need to temporarily install a plugin called “Duplicator” on your site. This will allow me to create a copy of your site and your content. Once the problem is resolved I will delete the local site. Please confirm if this okay with you.
Our Debugging Procedures
I will be checking various settings in the backend to see if the issue can be resolved. Although I won't be making changes that affect the live site, it is still good practice to BACKUP the site before providing us access.
Privacy and Security Policy
Kind regards,
Dennis
July 15, 2019 at 12:53 pm #4211201
pawelZ-10
Hi
I just instaled mamp server localy, as soon as I resolve localhost copy, will check plugins update, tried on webpage but got some errors from php so reverted to older versions
July 15, 2019 at 2:33 pm #4212237
pawelZ-10
It was problem with woocommerce-multilingual plugin, 4.6.0 version gave errors, 4.6.5 works ok
