Last updated by Marcel 8 months, 2 weeks ago.
Assigned support staff: Marcel.
September 5, 2019 at 12:08 pm
atakanI
The multicurrency function is not working on Products tabs rather than "ALL" tabs. For example, when you enter the city hidden link you see the products in dollar currency. But when you change the product tab you see the products in Ukrainian Hryvnia(the main currency)
Can you check it, please? I am adding screenshots for you
September 5, 2019 at 1:29 pm #4519609
Marcel
Hi Atakan,
This issue sounds quite similar to your reported issue with the Woodmart product filter. I want to test the issue the same way using a Sandbox.
Could you please try to reproduce the issue here on this isolated Sandbox? If you can reproduce it, I can report it to our Compatibility team. hidden link
Best Marcel
September 9, 2019 at 2:11 pm #4537893
atakanI
I need you to ask FTP access to upload my demo. By the way, I have created my mirror website here in WPML on another topic. If you can use it as a samle I will appreciate.
September 9, 2019 at 2:27 pm #4537989
Marcel
Hi Atakan,
you will find it under "WP Sandbox" in the left menu or here: hidden link
I kindly ask you to create a separate Sandbox for each ticket. When we debug this case, we may overwrite/delete options which are needed for your second support ticket.
Thank you for understanding.
Best Marcel
The topic ‘[Closed] Multicurency is not working on products tabs’ is closed to new replies.
