Last updated by Daren 9 months, 4 weeks ago.
Assigned support staff: Mihai Apetrei.
August 5, 2019 at 7:49 am #4338765
Daren
I have 2 simple forms created with EVEREST FORMS which was included in a free template that we liked. Can't see any place to translate these forms using WPML. Is EVEREST FORMS compatible with WPML?
August 5, 2019 at 9:32 am #4339323
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
I looked up the plugin name in our official WPML-compatible plugins directory here (https://wpml.org/documentation/plugins-compatibility/) but I was not able to find the plugin that you mentioned there.
Also, this is all that I could find out from the developers of the plugin regarding the translation of the forms:
- hidden link
- hidden link
I suggest that you contact the plugin authors and recommend them to join our 'Go Global' program (https://wpml.org/documentation/theme-compatibility/go-global-program/) where our Compatibility developers will help them make their plugin 100% compatible with WPML for free.
Also, please let me know if you have any other questions regarding this topic.
I will be happy to help out! 🙂
Kind regards,
Mihai Apetrei
August 6, 2019 at 12:25 am #4343275
Daren
Thanks, Mihai.
I have left a message with the developers.
If they don't respond, any recommendation for a WPML-compatible forms plugin (an easy-to-use one)?
August 6, 2019 at 1:27 pm #4347783
Mihai Apetrei
Hi.
Sure! One of the most popular form plugins that are used together with WPML is Contact Form 7. And it is free, too. 🙂
Here is the documentation that you would need to translate the CF7 forms:
https://wpml.org/documentation/plugins-compatibility/using-contact-form-7-with-wpml/
Please let me know if this solved your issue or if you still need help.
Kind regards,
Mihai
August 9, 2019 at 1:20 am #4366373
Daren
Contacted Everest Forms and while they claim to have some support for WPML through String Translation, we didn't find it to be a viable option. For now, we're including BOTH Japanese and English into the English forms that will be used on both language versions of our sites. That's the only fix for now.
Thanks for the recommendation.
