Last updated by Carlos Rojas 8 months, 1 week ago.
September 19, 2019 at 12:51 am #4600407
ralphG-7
I am trying to:
Migrate from polylang to wpml, the website have only 2 languages : French and English (as main language). Links seems to work great, but then after activating media translation, images are not synced together.
Don't have link sorry. It was on a staging site that I already reset, now I have done the migration again but without activating media translation this time.
I expected to see:
Images appearing in the correct language on the site.
Instead, I got:
English images appearing on french pages... When I open media translation tool, both french and english image appears, and are marked as waiting translation.
Another problem, is that I use smart slider on the homepage (at the beginning) but I don't find where to update the shortcode when I try to translate the homepage. So english slider appears on french & english homepage.
I need to migrate from polylang to wpml since I need the toolset plugins.
Links work correctly, and text is translated correctly too.
If it can help, I use elementor (free) as pagebuilder.
September 20, 2019 at 2:55 pm #4613093
Carlos Rojas
1.- I would like to ask you to follow this steps:
- Create a full backup of the site
- Go to WPML -> Settings -> Media Translation -> Select all options -> Click on Start button.
- Go to WPML -> Support -> Troubleshooting link -> Apply the troubleshooting steps highlighted in the attached image.
Could you tell me the results of the steps above?
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
September 20, 2019 at 7:13 pm #4614203
ralphG-7
Thanks for the reply,
I followed step 1 and 2 but the problem was there again.
So I restored the backup and do step 1 again.
And everything works fine now, I think I did not do the media translation setup at the right time during the first installation.
I will increase PHP memory limit again too.
September 23, 2019 at 9:16 am #4621905
Carlos Rojas
Could you confirm that the issue is solved?
Carlos
September 23, 2019 at 2:20 pm #4624921
ralphG-7
Thanks, the first problem is solved, but the second one is not yet :
I use smart slider on the homepage (at the top) but when I try to translate the page using wpml, I don't find where to modify it, I already have 2 slider (french and english).
The slider is added to the page with a shortcode ,I don't know if there is something to change in the settings of wpml to change shortcode according to language.
September 23, 2019 at 2:56 pm #4625253
Carlos Rojas
In this case I kindly ask you to visit this ticket and in the summary you will find the steps to follow in order to use Smart Slider with different languages: https://wpml.org/forums/topic/translation-smart-slider-3/
Carlos
September 27, 2019 at 7:45 pm #4656593
ralphG-7
Thanks, I will this article.
September 30, 2019 at 8:40 am #4663011
Carlos Rojas
Carlos
