Last updated by Noman 1 year ago.
Assigned support staff: Noman.
May 29, 2019 at 2:33 am #3911179
bernieR
I am trying to: Configure my navigation on mobile to see language switcher
Link to a page where the issue can be seen: amcmud.com
I expected to see: Language switcher
Instead, I got: Just the hamburger icon
May 29, 2019 at 4:25 am #3911675
Noman
Thank you for contacting WPML Support. Could you please follow below steps and let me know how it goes?
- I have noticed that your website’s WP Memory Limit is 40MB. The WP memory limit needs to be increased, it's different than php memory. PHP memory is fine but WordPress uses 40Mb as default in your site. Minimum requirements for WPML are 128Mb: https://wpml.org/home/minimum-requirements/
Please add this to the top of wp-config.php to increase WP memory:
/* WP Memory Limit */
- You are using older version of WPML plugins. Please backup your site and update ALL WPML plugins to it's latest versions. You can download it from your account: https://wpml.org/account/downloads/
If you face any issue in automatic updates please follow below steps:
1. Please take your full site backup.
2. Deactivate the existing WPML plugin.
3. Delete the plugin files – this does not delete your translations. You will simply delete the plugin files from your "wp-content/plugins" folder, NOT the database records.
4. Download the updated plugins from our servers (https://wpml.org/account/downloads/) and upload them to the plugin directory.
5. Activate the WPML plugin and add-ons.
- I have noticed that you are using an older version ( 17.8.4 ) of ‘Betheme’ theme and latest version of ‘Betheme’ theme is 21.2.2, please update the theme and see if this resolves your issue.
Thank you
The topic ‘[Closed] Need help with Switcher on mobile’ is closed to new replies.
