Our next available supporter will start replying to tickets in about 5.39 hours from now. Thank you for your understanding.
Problem: Using the "next_posts_link" secondary language link is not correct, throws the page 404 error not found.
Solution: If you are using a custom post type, you must translate the slugs of the page.
- On the WPML > Translation Management > Multilingual Content Setup - Click on the "Custom posts slug translation options" - Select the "Translate custom posts slugs (via WPML String Translation)." option - Scroll down and look for the "Custom posts" - Check the "Use different slugs in different languages for ..." - Translate the slug of the URL
Last updated by thomasS-2 3 years, 5 months ago.
August 31, 2016 at 9:48 am #1043404
thomasS-2
On the page Presse I have a post query with navigation that works well on German (orig language) and in English.
hidden link and
URL of website where problem appears:
hidden link throws an 404 Error
All the Posts are translated and I can not figure out why the same code does not work on french.
August 31, 2016 at 1:49 pm #1046767
Bruno
Thank you for contacting us.
This is a normal post or is a custom post type? If it is a custom post type, have you translated the slug "press" in French?
Also, please, click on the WPML > Support > Troubleshooting. Look for 'Clean up' and click on these buttons:
-- Clear the cache in WPML
-- Remove ghost entries from the translation tables
-- Fix element_type collation
-- Set language information
After following these steps, please let me know if the problem persists.
September 2, 2016 at 7:03 am #1054950
thomasS-2
thanks, you pointed me into the right direction. The slug of the french overview page was exactly the same with the category base slug. I've changed it and now all works well.
thanks
