This topic contains 20 replies, has 3 voices.
Last updated by Laura 1 year, 10 months ago.
July 18, 2019 at 12:27 pm #4238687
Laura
Can you please readd the credentials in the private reply? Since they were exposed I deleted them and I didn't save them.
July 24, 2019 at 2:07 pm
July 25, 2019 at 7:52 am #4280337
Laura
Hi Franziska,
thanks for the credentials.
I did some tests but I'm still not sure what is the issue here.
I placed an order in German, and it seems the same as the one you linked me as an example of the issue.
Please check screenshot orderDE and orderEN.
So I even tried to deactivate WPML and place a new order (in German, since it's the default language) but the product composition still seems the same to me. Please check screenshot nowpml.
Am I missing something here? What do you expect to see?
July 29, 2019 at 9:37 am #4298259
tobiasL-11
hmm it's stange it's working for you (orderEN). Because when I try it it doesnt work.
Here my test order and screenshot: hidden link
But what I noticed is, that the language mix doesn't appear in the order confirmation e-mail of the customer. There it's correct (see image attached).
Usually I would say: Ok, that's all that count's bit the problem is that we create invoices from the order in the backend and because in the backend the languages are mixed they also appear like this on the onvoice.
July 29, 2019 at 1:34 pm #4300231
Laura
Hi Franziska,
from your debug information I see the admin language is German. Can you try to switch to English and see if you get the same results like mine? It shouldn't work like that but at least we'll know what to look at.
August 6, 2019 at 1:45 pm #4347995
tobiasL-11
somehow my anser disappeared. Very sad... Yes I can confirm that this is solving the problem for the moment, but it's no solution, because we have to use the german language.
August 7, 2019 at 7:47 am #4352543
Laura
Hi Franziska,
yes, I can understand you need to use German, and it shouldn't work that way.
The compatibility team should take a look at this issue, but to do so, I really need to reproduce in a fresh installation.
I created a Sandbox for you: hidden link
Please configure WPML as it is on your site and install the plugin for Composite Products.
Then please create some options (it shouldn't be identical to your site - 1 composite product with a couple of options will do)
If you have problems displaying the products on the front end I'll try to do it.
Once we can reproduce the problem, I'll send it to the compatibility team.
The topic ‘[Closed] no translation within composite products in orders’ is closed to new replies.
