Last updated by Riffaz 1 year, 7 months ago.
October 14, 2018 at 2:43 pm #2815469
michaelP-15
I am trying to: All language switcher short code in revolution slider
I expected to see: Change language
Instead, I got: No aaction on click
October 16, 2018 at 12:24 pm #2820900
Riffaz
This is because of your menu.
The language switcher and the revolution slider is behind the menu.
So when you hover over the language switcher, actually you are hovering over the menu.
So the language switcher seems like not working.
You can check this by simply disabling the menu.
The menu and the revolution slider container are coded/created by the theme.
This needs some serious customization.
It better contacts the creators / the support forum of your theme.
or custom coding which is beyond the scope of our support. This being the case please consider contacting one of our certified partners from this link: http://wpml.org/documentation/support/wpml-contractors/
You will get the custom assistance you need to get on with your project.
Before doing so please have a look also here: http://wpml.org/documentation/support/wpml-contractors/guidelines-for-people-looking-for-consulting-help/
Riffaz.
The topic ‘[Closed] Not possible to click on language switcher embedded in revolution slider’ is closed to new replies.
