Last updated by brunoD-31 1 year, 7 months ago.
October 22, 2018 at 9:41 am #2837470
brunoD-31
I am trying to:
Show specific content according to the current viewing language.
This is a staging environment, I can't show you a specific page, but I can show you my code;
https://pastebin.com/ybpnqUeL
I added this code to my functions.php file of my child theme.
But for some reason only the else statement is loaded and it can't check if ($lang == "en") {
When I reload the page and check the var_dum() I load at the start I get the following flash:
I expected to see:
Text according to language.
Instead, I got:
Always the message in the else statement.
October 23, 2018 at 3:18 am #2840651
Shekhar Bhandari
Hello there,
I just tested the constant on my test server and I can see it's working without any issues. The code implementation you have is also correct, so it seems like an issue only in your site.
As a test could you please use the constant inside the function once and see if that helps?
Further, could you please perform the below steps and share me the results?
Debugging
1. Please follow the debugging information provided here: http://wpml.org/documentation/support/debugging-wpml/
2. Repeat the action of creating the problem.
3. Copy and paste the contents of debug.log (log file inside the /wp-content/ directory) here for me to see.
Look forward to your reply.
October 25, 2018 at 2:06 pm #2850087
brunoD-31
