Last updated by Noman 8 months ago.
Assigned support staff: Noman.
September 26, 2019 at 11:10 am #4645999
saschaM-11
I am trying to: I translated my landing page with wpml and some parts of my page are not found by your plugin. So i have to translate it manually. Why it doesn't find those text parts?
I expected to see:
I expect to be able to translate the whole page with your plug in
Instead, I got:
I can only translate half o my page with wpml, the rest manually
September 26, 2019 at 11:39 am #4646355
Noman
Thank you for contacting WPML Support. Could you please follow below steps and let me know how it goes?
1. I have noticed that your website’s WP Memory Limit is 40MB. The WP memory limit needs to be increased, it's different than php memory. PHP memory is fine but WordPress uses 40Mb as default in your site. Minimum requirements for WPML are 128Mb: https://wpml.org/home/minimum-requirements/
Please add this to the top of wp-config.php to increase WP memory:
/* WP Memory Limit */
2. Various Visual Composer modules are supported by WPML and will automatically be displayed on the Translator Editor page. Here you can see list of all supported modules:
https://wpml.org/documentation/plugins-compatibility/how-to-build-multilingual-sites-with-wpbakery-page-builder-and-wpml/#supported-modules
2.1 And here is a guide on how to make custom VC elements WPML translation editor compatible:
https://wpml.org/documentation/support/wpml-integration-with-page-builders-that-use-shortcodes/
https://wpml.org/documentation/support/language-configuration-files/
Please let me know if this resolves your issue or you need further assistance with this issue.
Thank you
September 26, 2019 at 11:50 am #4646427
saschaM-11
Thanks, will try it and get back to you.
September 26, 2019 at 12:53 pm #4646965
Noman
Okay sure thanks.
The topic ‘[Closed] Only translates parts of my page’ is closed to new replies.
