Problem: Translated pages are missing the main body content from the original page.
Solution: The client resolved this by deleting pages and creating the news pages with the content
0% of people find this useful.
Our next available supporter will start replying to tickets in about 2.74 hours from now. Thank you for your understanding.
Last updated by julienF-5 3 years, 3 months ago.
April 4, 2018 at 2:57 pm #1565005
julienF-5
Hello Team
I know it's an known issue, I read some thread support regarding this but I don't solved my problem
I am trying to translate the body of page using the translation editor but the body field doesn't appear
I expected to see the body field
Instead, I got nothing
Thx for your Help
Julien
April 5, 2018 at 1:08 pm #1566029
Lauren
First, please go to WPML -> Translation Management and if there is a translation job in process for this page, mark it as complete or cancel it.
Next, please go to Plugins -> Add New and click on the Commercial tab. Click "Check for Updates".
Now, go to the page in the original language. Make any small change and click Update. Now, when you edit your page, do you see the content/body fields available for translation?
If not, please try temporarily switching back to the parent theme and follow these steps again.
Please let me know the results of these tests. Thanks!
April 7, 2018 at 1:08 pm #1568388
julienF-5
Hello Lauren
Thank you for your help
I followed your process and guidelines but unfortunately, it still doesn't work
Julien
April 9, 2018 at 3:53 pm #1573971
Lauren
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
April 10, 2018 at 4:53 pm #1584894
Lauren
Thanks for sending credentials. I believe the body form is not showing because the only content in there is a shortcode, which most likely has not been declared in a wpml-config.xml file. Please see the following documentation which can walk you through how to add custom shortcodes and create a wpml-config file. You can also paste the custom cofig code to WPML -> Translation management -> Custom XML Configuration. https://wpml.org/documentation/support/language-configuration-files/
Alternately, you can go to WPML -> Translation Management -> Multilingual Content Setup and change the settings to translate manually instead of using the Translation Editor. This will open the translated pages in the native WordPress editor and you can add/change the shortcode as needed.
April 11, 2018 at 7:11 am #1590174
julienF-5
Hello Lauren
Thank you for your support
I found a solution by deleting pages and creating the news pages with the content
Thank you
