This topic contains 13 replies, has 3 voices.
Last updated by Marcos Vinicios Barreto 10 months ago.
Assigned support staff: Marcos Vinicios Barreto.
October 31, 2019 at 8:41 am #4861629
hanne-mariM
I am trying to:
Create products by using the WooCommerce API (the product information comes from an external ERP system with API integration). I'm trying pair translations with the main language. The translations were created at the same time as the main language product by the API.
I expected to see:
Product translations under the main language product.
Instead, I got:
Only the translations are paired together and create a duplicate SKU product, and are not paired with the main language product
November 1, 2019 at 9:22 pm #4873071
Lauren
Thank you for contacting WPML support. I'll be happy to help you with this. Here is a link to our documentation: https://wpml.org/documentation/related-projects/woocommerce-multilingual/using-wordpress-rest-api-woocommerce-multilingual/. You will want to be sure to use the "translation_of" parameter when adding the translated products, as outlined in the documentation.
November 4, 2019 at 10:20 am #4879719
hanne-mariM
This is already in order, every translation gets translation_of -value. Is there any way to debug this?
November 4, 2019 at 1:59 pm #4881797
Lauren
Since you are trying to create the translations at the same time as the default language, what are you using for the translation_of? For example, in the documentation, we show this:
'translation_of' => '23'
What are you using for the actual ID? Feel free to paste the full code you are using so we can take a look.
November 7, 2019 at 11:05 am #4905123
hanne-mariM
Here's how it works (pseudo code).
foreach (payload as product) {
    if (sku exists at woo) {
        add woocommerce ID to product
        add update flag to product
    if (update flag is set) {
        remove sku from product data
        remove update flag from product data
        PUT product data to woocommerce
        skip translation handling
    } else {
        POST product data to woocommerce
        get woocommerce ID from response
        if (product has translations) {
            add main product woocommerce ID to translation
            POST translation product to woocommerce
November 8, 2019 at 1:58 pm #4913907
Lauren
Please provide the actual code instead of the pseudo code so we can take a look. Thanks.
November 15, 2019 at 9:50 am #4952389
hanne-mariM
The code is written by a 3rd party. I'm not sure if they are willing to share it with us, but I try.
November 15, 2019 at 3:07 pm #4955145
Lauren
Okay great, please let me know when it is available for us to review.
November 20, 2019 at 11:25 am #4979303
hanne-mariM
Hi, can you mark the next answer as private so I can provide the code? 🙂
November 20, 2019 at 4:13 pm #4982085
Lauren
The next reply has been set to private so that you can share the code. Thanks!
November 22, 2019 at 2:50 pm #4999303
Lauren
Thanks for sharing. Our developers took a look at the code and noticed that you are are missing the lang param when posting translation_of https://wpml.org/documentation/related-projects/woocommerce-multilingual/using-wordpress-rest-api-woocommerce-multilingual/#create-products. That needs to be added to the code. You can review the documentation I have linked to see how it should be added.
November 26, 2019 at 12:34 pm #5021429
hanne-mariM
That's not actually true, because the lang-field comes already from the source system. The data looks like this, so the translation_of is filled filled up on the fly. That's why it doesn't show up in the code. So this cannot be the reason.
 'name' => 'Product Title',
        'lang' => 'en',
        'translation_of' => '',
        'description' => '',
        'short_description' => ''
November 26, 2019 at 7:22 pm #5024817
Timezone: America/Bahia (GMT-03:00)
Thank you for the updates, I am covering Lauren here, as she is taking some days off. I've forwarded your message for our second level support, I will update you here as soon as I have some more details from them. Thank you for your continued patience and understanding, have a nice day.
November 27, 2019 at 6:22 pm #5031819
Thank you for your continued patience while waiting for a solution. According our second level support there's still some missing paramenters for the product translations such as 'type', 'price' and so on as you can read at: https://wpml.org/documentation/related-projects/woocommerce-multilingual/using-wordpress-rest-api-woocommerce-multilingual/#create-products. In any case, we would need to confirm if the same issue is replicable in a clean sandbox environment, for that, please proceed like this:
1 - Access this sandbox environment at: hidden link. It is a one click login url.
2 - Setup it according your website, in your case it would be:
2.1 - WPML Setup at WordPress Dashboard > WPML
2.1 - WooCommerce and WooCommerce Multilingual plugin activation and setup at WordPress Dashboard > Plugins
3 - Try to create your products and products translations in this new environment via REST API.
Please, let me know if you can reproduce the same issue, so we can escalate it properly for our second and third level support or compatibility team. Thank you for your collaboration and continued patience, have a nice day.
The topic ‘[Closed] Pairing problem with WooCommerce products created by the WooCommerce API’ is closed to new replies.
