Problem: All "vc_column_text: content" parts are not showing the entered translation
Solution: - Edit the page in English -> Make small changes in the elements -> Save the changes -> Translate the page using the Translation Editor -> Make sure all fields are translated and all 'Translation is complete' option are selected -> Save the translation.
Relevant Documentation:
Our next available supporter will start replying to tickets in about 6.07 hours from now. Thank you for your understanding.
Last updated by sarahE-4 2 years, 1 month ago.
April 16, 2018 at 10:12 pm #1653106
nicolasD-53
I am trying to: Add all translations
I expected to see: The translated text
Instead, I got: The original text
April 18, 2018 at 12:01 am #1668222
Carlos Rojas
1.-Please provie the steps to reproduce the issue.
2.- I would need a sites snapshot if possible.
We usually recommend the free Plugin “Duplicator” for this porpoise.
If you already know how Duplicator works (http://wordpress.org/plugins/duplicator/),
please skip the following steps and just send me the installer file and the zipped package you downloaded.
★ Duplicator Instructions: hidden link
Send me both files (you probably want to use DropBox, Google Drive, or similar services, as the snapshot file will be quite big)
❌ IMPORTANT ❌
Remember to create or keep an admin account for me before creating the snapshot, or I won’t be able to login. You may delete the new admin account once the snapshot has been built.
I will enable your next answer as private so you can provide me the information securely.
3.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
April 20, 2018 at 3:22 pm #1728361
Carlos Rojas
Hi Nicolas,
I'm downloading the copy of the site. My next step will be trying to isolate the cause of the issue on a local environment.
I will get back to you as soon as I have an answer.
Thank you very much for your patience!
Kind regards,
Carlos
April 20, 2018 at 5:25 pm #1731095
Carlos Rojas
Hi Nicolas,
It seems you forget to share the installer.php file. Could you share a download link to this file?
I have set your next answer private.
Carlos
April 20, 2018 at 9:05 pm #1733648
Carlos Rojas
Hi Nicolas,
I would liket to ask you to follow this steps:
Could you tell me if the issue is solved?
Note: You may need to do this twice.
Kind regards,
Carlos
September 20, 2019 at 7:29 pm #4614275
sarahE-4
I am having precisely the same problem. The suggested solution (make small change, re-translate) did not resolve the issue.
