This topic contains 25 replies, has 2 voices.
Last updated by George Botsev 5 years, 2 months ago.
Assigned support staff: George Botsev.
November 4, 2016 at 8:22 am #1129882
Sander
I have been talking to Amir in this post:
https://wpml.org/2016/10/all-set-woocommerce-multilingual/?replytocom=1562179#respond
I experience a lot of performance issues with Sitepress Multilingual Cms and Wpml String Translation. Amir told me to open a ticket here so you can give me some support.
November 4, 2016 at 8:43 am #1129905
George Botsev
Timezone: Europe/Sofia (GMT+02:00)
Hello, I am George from third tier support and I will try to help you with the issue.
In my experience, the issue may be related to W3 Total Cache - if not configured properly or if it is set to cache method to "DISK" - this usually somewhat degrades the performance because of the disk slowness.
Maybe it would be a good idea to test how it loads without W3 Total Cache?
The plugin P3 performance profiler is to general in its description of the problem.
Could you perhaps test with the plugin Query Monitor and/or Debug objects?
Also, it would be very nice, if I could get a temporary access or a duplicator clone of your site so that I could try to debug the issue.
I am activating the private reply so that you could share temporary login credentials with me (if you wish).
If you allow me to access your site, in the end, I would like to create a site clone with Duplicator.
Please let me know if I have your permission to do that.
November 4, 2016 at 9:10 am #1129930
Sander
Hi George,
The reason why I implemented W3 Total Cache in the first place was because the site was so slow. 🙂 I have shared the login details to my site. I'm also working with my hosting provider this morning to migrate to a VPS (also as a result of the slow performing site), I'm exploring all options here. 🙂
November 4, 2016 at 9:41 am #1129962
George Botsev
I am afraid that I cannot access your site.
There seems to be a problem and I was blocked by your security measures.
It seems that the site is too much cached and the only security question for the login that I've got is 16-2 - and this several times.
I think that there might be something very wrong with your caching setup - perhaps some of the plugins that you use (like the one for the math question for login) are not working properly with caching.
This might explain other performance issues too - if you are using very old or obsolete plugins.
Could you take a look please?
November 4, 2016 at 10:13 am #1130007
Sander
Hi George,
I disabled W3 cache. Can you please try again?
November 4, 2016 at 11:02 am #1130045
Sander
Were you able to test it?
November 4, 2016 at 1:40 pm #1130198
George Botsev
I just tested.
Now the captcha works, but the credentials that you provided for me return that they are not correct.
Perhaps there is some mistake in them - you can edit your private post and correct them.
November 4, 2016 at 1:40 pm #1130199
George Botsev
I just tested.
November 4, 2016 at 1:41 pm #1130203
George Botsev
Maybe it would be faster if you provide me with Duplicator clone link.
I am activating the private reply once more for that.
November 4, 2016 at 2:20 pm #1130256
George Botsev
My IP address is blocked.
Please upload for me somewhere a duplicator clone so that I can investigate the issue.
November 4, 2016 at 2:48 pm #1130288
Sander
Hi George,
I created a duplicator package. I put the weTransfer URL in the "URL to admin" area.
Can you confirm you were able to download it?
November 4, 2016 at 2:52 pm #1130290
George Botsev
Thank you very much!
I confirm that I am able to get the file.
I will get back to you as soon as I get it and run some tests.
November 4, 2016 at 3:51 pm #1130332
George Botsev
Hello, it seems that the duplicator that you sent me has some files missing - mainly related to the theme in the /inc/ folder.
There were some other files missing too like in example the core plugin for WPML - but I replaced it with a working copy.
Running your site with a standard theme and debugging it for performance issues produces very fast loading speeds for me, and I am unable to find the performance problem.
Could you please upload separately perhaps the missing files?
Can you guide me to a page where the performance issue is most prominent?
November 4, 2016 at 4:39 pm #1130373
Sander
Is there a way we can communicate a bit faster? Via skype or another chat application?
November 4, 2016 at 9:08 pm #1130492
Sander
I think the best way for you to examine my site is to log in to the site itself. I disabled the Captcha and made sure you ip is nog blocked. Can you please try to login again?
The topic ‘[Closed] Performance issues with Sitepress Multilingual Cms and Wpml String Translation.’ is closed to new replies.
