Problem: What can I do to optimize WPML performance?
Solution: WPML 4.3 version solved the performance issues that some sites experienced. Updating to the latest version of WPML and its add-ons should resolve the problem.
If you are still running into performance problems, first follow our FAQ entry about preventing performance issues with WPML. This FAQ includes a number of simple steps to follow.
In case you want to profile your site's performance and get to the bottom of performance problems, follow the guide for debugging performance problems.
Last updated by Carlos Rojas 10 months, 1 week ago.
July 30, 2019 at 7:40 am #4305381
stephaneM-32
We have a huge problem of load and WPML does not help here with the plugin wpml-string-translation.
This query is nearly 1 second :
SELECT DISTINCT s.id, s.name, s.context, st.status, s.gettext_context, st.value AS tra, st.mo_string AS mo_string, s.value AS orig
FROM wp_icl_string_pages sp
INNER JOIN wp_icl_string_urls su
ON su.id = sp.url_id
INNER JOIN wp_icl_strings s
ON s.id = sp.string_id
LEFT JOIN wp_icl_string_translations st
ON s.id=st.string_id
AND st.language=su.language
AND s.language!=su.language
WHERE (su.language='fr' and su.url='/wp-admin/edit.php') or (su.language='fr' and su.url IS NULL)
We've installed the last version of WPML plugins and we have a WooCommerce 4.9 and WooCommerce 3.4.
I would like to know how can we fix this cause it slow the website entirely.
We have also this query which is globally for wordpress :
SELECT option_name, option_value
FROM wp_options
WHERE autoload = 'yes'
July 30, 2019 at 4:50 pm #4309803
Carlos Rojas
Could you provide some screenshots with the loading time of the site? This way I can use it as a reference.
Kind regards,
Carlos
July 30, 2019 at 8:14 pm #4310395
stephaneM-32
Here is a screenshot, the best is to visit hidden link and add a product in cart.
You'll see the slow delay.
Regards
July 30, 2019 at 11:45 pm #4310747
Carlos Rojas
Our Debugging Procedures
Carlos
July 31, 2019 at 12:45 pm #4314423
Carlos Rojas
I tried to log in the site but I don't have the credentials for the pop-up that appears right before displaying the log-in page. Could you edit your previous private message and provide this credentials?
Also, if you create a staging site I rather get the credentials for this staging site and run the tests there (as you mentioned). So, once you have the staging site I kindly ask you to provide the access credentials. I have set your next answer private for this purpose.
Carlos
Carlos
July 31, 2019 at 1:15 pm #4314659
stephaneM-32
Touch nothing please we are in production so no updates or other thing OK. I will prepare a staging ad give you access. I did not do backup of production right now.
Thanks to confirm me
July 31, 2019 at 2:06 pm #4315161
Carlos Rojas
Thank you for your message.
In this case I will wait for you to create the staging site and provide the access credentials. I have set your next message private.
Carlos
