If you are having a notice about writing the .mo files please read this doc
Hi, Amit here, I am the WPML Support Manager, our current ticket queue is high, update your WPML plugins and make sure you meet the minimal requirements for running WPML before reporting an issue please - many tickets are resolved doing that
Please look at our updated list of Known Issues and you can also use our support search to find helpful information and of course review our documentation before opening a ticket.
If you do need to open a ticket please make sure to provide us with all the needed information as described in this page
Last updated by Ellery 6 years, 4 months ago.
Assigned support staff: Harshad.
June 19, 2013 at 10:57 am #137148
Ellery
Hi
First of all, here is my config:
- Windows 7, Apache 2.2, PHP 5.3.8
- WPML: 2.8.2
- WP: 3.5.1
- WooCommerce 2.0.12
- mod_rewrite available, .htaccess writable
WPML Config:
- Language name added as a parameter
- Sticky link enable
I setup navigation menu BEFORE installing WPML. And my theme is using option-tree to save theme setting. My theme is called tendershop (Bought from ThemeForest).
My questions:
- So, I create a custom menu with custom permalink and works fine. After I installed WPML, since permalink keep unchanged in custom menu item, I cannot make it automatically direct to desired language. How can I fix it?
- There are some text in option-tree which will be used to be displayed on front-end. But it is just English (default language). I would like user to see different languages based on their language selection. How can I do it?
- I ran sticky link scanning (Scan All Posts). But it seems that the permalink problem still exists. Am I right using Sticky link to solve that?
Included please find some of the images for your information.
- 1,2,3.png are plugin list
- 4.png: .htaccess content
- 5.png: setting of permalink in nav menu
- 6.png: option-tree link, want to make it language dependable
Thank you in advance for help!
June 19, 2013 at 11:01 am #137158
Ellery
Image 3, 5, 6 are wrong. I can't update it, so I re-upload here
June 19, 2013 at 1:26 pm #137223
Harshad
Dear Ellery,
--> When you add a custom link to default language menu, you will have to manually create a custom link to your secondary language menu and update the links, As custom links don't take part in Menu Syncronization.
Only posts/pages categories, Only if they are translated will be created automatically after Menu sync.
--> I guess option tree plugin is not compatible with wpml yet, may be solution provided by Peter in this post should help you
http://wpml.org/forums/topic/option-tree-wpml-translation-not-working/#post-56236
--> Can you please resave permalinks from Settings -> Permalinks, Then go to wpml -> support, click on the troubleshooting link at the bottom of the page.
On troubleshooting page click "Set language information" button.
June 20, 2013 at 9:44 am #137462
Ellery
Thank you. For the first and third problems, now they are solve.
For second one, I am looking forward to see it compatibles.
June 24, 2013 at 9:51 am #138375
Ellery
I solve my second one by myself. My log of action stated here:
Hope it helps someone.
