Last updated by liuM 10 months, 3 weeks ago.
July 2, 2019 at 6:50 am #4124353
liuM
I updated wpml and found that I tried to duplicate in the post, but it didn't have any response.
Normal before it is updated
Look at the attachment image.
July 2, 2019 at 9:35 am #4125393
Raja Mohammed
I will help you with your issue.
The issue seems to be a JS conflict, Try using Google Chrome built-in console to see if there are any errors displayed. You can access the console from the Google Chrome Settings > Tools > JavaScript Console.
It would be good if you can provide me with the WordPress debug.log (not WPML debug information).
To enable it, open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to:
define('WP_DEBUG', true);
In this case, the errors will be saved to a debug.log log file inside the /wp-content/ directory.
If you can paste your debug.log to pastebin.com and provide me that link it would be great! (This is the cleanest way because sometimes the logs are long and create a complete mess in the discussion).
Kind regards
Raja
July 2, 2019 at 12:45 pm #4127039
liuM
Hi
I think it is really a JS conflict.(Figure)
I am trying to enable debug.log
But I didn't find it in the wp-content directory, so I can't provide you with more log information.
July 3, 2019 at 4:34 am #4131769
Raja Mohammed
Thanks for the screenshot, The issue seems similar to the known issue with an older version of WPML, I'm not sure about the version of WPML used in your site please provide WPML debug information with can be obtained from WPML > Support
https://wpml.org/faq/provide-debug-information-faster-support/
Please follow the below steps :
Recomended: Secure a backup of your site and database
1) Update WPML to the latest version if not already updated
2) Fix mixed content issue the site is loaded over https and the resources are loaded over http
3) Disable all non-WPML plugins check if the issue can be reproduced
Let me know the results
Kind regards
Raja
July 10, 2019 at 1:37 am #4175029
liuM
Hi Raja
I am using the latest wpml. But I found that the wordpress version is 5.1 which causes the work to not work properly, updating to 5.2.2 everything is fine.
