Please make sure to update to WPML 4.3.5 and check our list of Known Issues before reporting
Hi, Amit here, I am the WPML Support Manager, our current ticket queue is high, update your WPML plugins and make sure you meet the minimal requirements for running WPML before reporting an issue please - many tickets are resolved doing that
Please look at our updated list of Known Issues and you can also use our support search to find helpful information and of course review our documentation before opening a ticket.
If you do need to open a ticket please make sure to provide us with all the needed information as described in this page
Last updated by Riffaz 8 months ago.
February 18, 2019 at 7:37 am #3210371
doronN
I am trying to Translate a post, when clicking on "save and close" it is stock on saving and nothing happens. - tried changing the theme to default and disabling plugins - still stock.
February 18, 2019 at 9:13 am #3210649
Riffaz
Please enable the WP Debug ode as explained here: https://wpml.org/documentation/support/debugging-wpml/
Save a post.
Let me know the error messages you are seeing.
Riffaz.
February 20, 2019 at 10:02 am #3220681
Riffaz
A JS error may stop the rest of the JS execution, so this could be the reason.
It's webshocket related issue. so server related.
Could you please show this error to your hosting company and check with them?
If you still unable to save the posts after fixing this issue, let us know please.
February 24, 2019 at 7:58 am #3236321
doronN
The JS error is from jetpack. Disabled jetpack and the issue is NOT resolved.
Also - disabled all plugins and set the default 2019 theme nd the issue is NOT resolved.
Any further advice?
February 24, 2019 at 2:39 pm #3236836
Riffaz
I am setting the next reply as private.
Let me know your site login details to check this closely.
February 25, 2019 at 2:03 pm #3240198
Riffaz
Thanks for the login details.
I've recorded a video: hidden link
1. I created a test page
2. Translated to English
Translation editor works fine and when I click on "save & close" it works as expected.
Original page and the translation also work fine: hidden link
This is how it should work. Are you referring to something else or this has been fixed?
Anyhow, I see many JS errors in the console when work with posts and translations.
All are related to other plugins.
This may cause issue on your end.
Let me know how it goes.
February 26, 2019 at 8:45 am #3243527
doronN
Try the arab translation of this post
I don't see JS Error - it looks like the one you see are (maybe) for extensions you run
February 26, 2019 at 9:59 am #3244001
Riffaz
Yes, in that page Arabic translation just freezes like this hidden link
So this happens only on this page, right?
I suggest you to copy the content of this page and paste it into new page and then try to translate.
If not, just enable the WP Debug mode as explained here https://wpml.org/documentation/support/debugging-wpml/ and try save that post again.
And give me the new errors you see on the screen or the debug.log file.
February 28, 2019 at 1:57 pm #3255600
Riffaz
Thank you for the details.
I checked this with the team.
All suspect this because of your max input vars.
Please increase your MaxInputVars to 10000 and the WP Memory limit (https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP) to as much as you can and then check the issue.
MaxInputVars:
You can use php.ini or .htaccess if your host allows.
=> php.ini file
Open the php.ini file and insert/edit this line:
max_input_vars = 10000
=> .htaccess file
php_value max_input_vars 10000
Sometimes if you are in a shared hosting you have to contact your hosting support for this.
March 4, 2019 at 12:04 pm #3268467
Riffaz
Sorry for the delay.
We had to inspect a lot regarding this.
Admin ajax fails on that page when we try to save the translation: hidden link
1. Could you please delete all the errors you have in your error.log?
2. And, enable the WP Debug mode: https://wpml.org/documentation/support/debugging-wpml/
3. go to the translation editor in the page that hangs
4. open developer tools and go to network tab
5. click 'save and close'
6. a new entry should show in the network tab, check the response
7. click on the admin-ajax.php
Now check your debug.log and there should be some errors on the file.
Send us it.
This is very that we don't have any error message in the debug log even after this.
In that case we need to replicate your site and need to check it in our hosting locally.
Let me know.
March 8, 2019 at 10:19 am #3291148
doronN
This is what appears on the log after I cleared it
[08-Mar-2019 10:14:18 UTC] PHP Notice: Trying to get property of non-object in /home/dialogto/domains/dialogtogether.com/public_html/wp-content/themes/armonioso-child/functions.php on line 127
[08-Mar-2019 10:14:18 UTC] PHP Notice: Trying to get property of non-object in /home/dialogto/domains/dialogtogether.com/public_html/wp-content/themes/armonioso-child/functions.php on line 128
After I click save, the admin-ajax.php in developer tools ->network->XHR
{"success":false,"data":0}
The saving Icon is stock and wp-admin keeps producing wp-auth-check ever couple of minutes
{"wp-auth-check":true,"server_time":1552039988}
{"wp-auth-check":true,"server_time":1552040048}
{"wp-auth-check":true,"server_time":1552040168}
{"wp-auth-check":true,"server_time":1552040288}
I can create a testing environment on my server - for you to fiddle with as much as you want. Let me know if that will work and how to send the details
Doron
March 11, 2019 at 10:16 am #3309653
Riffaz
I've sent this to our team to check this internally.
Please be patient till we get back to you.
March 21, 2019 at 11:38 am #3400081
doronN
Hey
Migration completed
March 24, 2019 at 6:07 am #3447767
Riffaz
I do not work on Fridays and saturdays.
Did you check the migrated site?
It goes 403 : hidden link
I will check this again with the corresponded department and will get back to you on Monday evening.
March 24, 2019 at 8:24 am #3447871
doronN
When I visited it was OK (after the migration) check with hosting support.
