Last updated by Marcel 1 month, 3 weeks ago.
Assigned support staff: Marcel.
June 12, 2020 at 2:44 pm #6360409
tomB-16
I have a post with a certain slug. In the same language, there is a page with the same slug.
When trying to visit the post (example.com/blog/certain-slug), I get redirected to the page (example.com/certain-slug).
I have a custom permalink structure: /blog/%postname%/
How can I have the post and page with the same slug show correctly?
June 15, 2020 at 9:35 am #6371551
Marcel
WPML will allow you to have the same slug for different languages (https://wpml.org/forums/topic/same-slug-across-different-languages/). But you get here into trouble even without WPML.
Example:
Let's say you have a post and a page with the same slug, WordPress will always redirect you first to the page:
Page: hidden link
Post: hidden link
This happens also without WPML. You can solve this with custom redirect rules.
Best Regards
Marcel
June 15, 2020 at 9:40 am #6371579
tomB-16
If i disable WPML, there is no problem, because the base is different.
page: hidden link
post: hidden link
Kind regards,
Tom
June 15, 2020 at 10:04 am #6372133
Marcel
My test was based on the same base (without /blog permalink). I would recommend you to use custom redirect rules to solve this.
Best Regards
Marcel
June 15, 2020 at 10:10 am #6372153
tomB-16
Can you please re-try without WPML & custom permalink structure: /blog/%postname%/
/my-test will correctly show the page
/blog/my-test will correctly show the post.
After activating WPML, /blog/my-test gets redirected to /my-test
June 16, 2020 at 4:28 pm #6385655
Marcel
thanks for the info. I was able to reproduce it. I will make some further tests and update you ASAP.
Best Regards
Marcel
June 17, 2020 at 9:50 am #6392219
Marcel
when WPML is active the /blog/my-test cause a 301 redirect:
>>> <em><u>hidden link</u></em>
> 301 Moved Permanently
Status:    301 Moved Permanently
Code:    301
Server:    nginx/1.14.0 (Ubuntu)
Date:    Wed, 17 Jun 2020 09:28:58 GMT
Content-Type:    text/html; charset=UTF-8
Connection:    close
X-Redirect-By:    WordPress
> 200 OK
I escalated your case to our devs. I will update you once I receive feedback.
Best Regards
Marcel
June 18, 2020 at 2:14 pm #6404591
Marcel
our devs informed me that they are aware of the problem. I escalated your case to the backlog entry, so we can inform you once it gets solved.
Currently, there is sadly no temporary workaround for this issue.
Best Regards
Marcel
