Problem: Instead of seeing the translated posts, I see "nothing found here" on the category elements.
Solution: Go to WPML > Support > Troubleshooting -and click on the button "Synchronize posts Taxonomies" make sure "Posts" are selected in the drop down menu.
Relevant Documentation: https://wpml.org/forums/topic/synchronize-post-categories-to-translated-posts/
Last updated by davidF-76 1 year, 2 months ago.
Assigned support staff: Marcel.
May 26, 2019 at 7:06 pm #3892327
davidF-76
See the reader responses here:
They are all translated.
Instead of seeing the translated posts, I see "nothing found here" in the Arabic version:
All of my categories are translated in the taxonomy editor, I believe.
May 27, 2019 at 8:56 am #3894927
Marcel
Languages: German (Deutsch )
It looks like Arabic is not a visible language, or there is no content translated to Arabic. Could you please send me a specific example, as the URL with ?lang=ar redirected to English.
Please let me know.
Best Marcel
May 28, 2019 at 5:29 am #3902797
davidF-76
Hi Marcel, I have made Arabic visible now to anyone.
You can see the Arabic HP here:
The english HP here:
My concern is specifically around the widget next to the "See all reader responses" link
May 28, 2019 at 7:13 am #3903247
Marcel
Hi David,
thank you. I can follow the issue now.
I would need to request temporary access (WP-Admin and FTP) to your site
in order to be of better help and check if some configurations might need to be changed
✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important.
✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen
Best Marcel
May 29, 2019 at 8:24 am #3913017
Marcel
Hi David,
could you please provide me with full admin access? Otherwise, I don't have the right to open the translation to check if it's loading the correct category ID of the blog posts.
Thank You
Best Marcel
May 29, 2019 at 7:24 pm #3918325
davidF-76
Done.
May 30, 2019 at 4:36 pm #3924989
Marcel
the problem is indeed that the posts are loaded with the wrong category id:
Example:
English "Reader Responses" = ID 92
in Arabic = ID 99
It looks like there is no option in the Theme to make the "Isotope" Post element translatable, even not If I activate the radio buttons for it on the bottom of the page. I will try to make it translatable via a custom XML config. It could be that this element is added new to the Uncode Theme, this I need to find out.
Please give me some time to try this out.
Best Marcel
May 30, 2019 at 5:13 pm #3925285
davidF-76
Thank you, Marcel. Is there a workaround we can pursue in the meantime or do we expect that a fix can be reached in <24hours? Thank you again.
June 2, 2019 at 5:31 pm #3937777
davidF-76
Hi, I resolved this issue by following the steps here:
