Last updated by arminS-15 11 months, 1 week ago.
Assigned support staff: Vincenzo.
February 1, 2019 at 1:09 pm #3151662
arminS-15
Hello WPML Team,
I am trying to:
Show translated posts in a post list for our news page.
We use elementor as a page builder and 'Elementor Addons & Widgets' plugin along with other plugins. The origin language is german which is translated to english.
When we translate the posts, the post content is not shown in the list of the english version.
I've created a dummy page showing this problem (sorry, the layout styling isnt good at this page):
I expected to see:
-First post is created in german and afterwards translated to english:
german works, english: post content not showing
- second post is created in english than translated to german:
both, german and english not working. Here i also added post excert, whic does work in both
- the test post, just ignore it..
Three tests made with this elementor elements:
1. EAW Post Grid
2. Standard elementor post element
3. EA Post Grid (Essential Addons for elementor plugin)
Errors encountered in backend:
- Sometimes server error 500 while saving elementor changes (in frontend editing) but things are saved
- On translating posts, some fields doesent appear in the translator for editing
- when reopening the translations editor some fields are unchecked again
- while saving in translations editor nothing happens. For example clicking on 'Save & Close' button, the animation 'Saving...' starts but no action of the page
Thank you for your help!
Instead, I got:
February 2, 2019 at 3:02 pm #3154347
Vincenzo
Hello, thank you for contacting WPML Support!
1. From your description, these seem like known issues that are already been solved in the latest versions of Elementor and WPML plugins.
Can you please update your site to the latest versions of Elementor, WPML and its active add-ons?
You can check the latest released versions under “My Account -> Downloads” on this site.
- https://wpml.org/account/downloads/
Instructions to update can be found here:
- https://wpml.org/faq/install-wpml/#automated-updates
❌ Before proceeding please make a full website backup! ❌
2. The WP Memory Limit needs to be increased. PHP memory limit is fine but WordPress uses 40Mb as default. Minimum requirements for WPML are 128Mb.
Add this near the top of wp-config.php file (after the php opening tag) to increase WP memory:
/** WP Memory Limit */
define( 'WP_MEMORY_LIMIT', '128M' );
The wp-config.php file is located in your WordPress root directory. It's the same file where the database configuration settings are. You will have to access it by FTP or SFTP in order to edit it.
You can check the current WP Memory Limit value from WPML -> Support in the Info section
More info here:
- https://codex.wordpress.org/Editing_wp-config.php#Increasing_memory_allocated_to_PHP
- https://wpml.org/home/minimum-requirements/
Please let me know if this solves the issue or if you need further details.
Thank you
February 8, 2019 at 3:42 pm #3175999
arminS-15
Hello Vincenzo,
thank you for your support so far..
While updating all relevant plugins, i encountered a problem with updating the WPML Plugins.
Update of the WPML Multilingual CMS got an error at first, than somehow after second attempt, it was updated to v4.2.0
WPML Media error:
Update Failed: The package could not be installed. PCLZIP_ERR_BAD_FORMAT (-10) : Unable to find End of Central Dir Record signature
Also state changed to deactivated and not able to activate again
WPML String Translation error:
Update Failed: Download failed. Not Found
WPML Translation Management error:
The WP memory limit is set to 128M successfully
How can I proceed? What if i download the current versions of those three plugins and install it via upload funktion? Would it override some settings?
Do you need to login to the page, icould provide you the credentials.
Best regards and thanks!
February 8, 2019 at 3:52 pm #3176058
Vincenzo
this is a known issue. Our Systems team is working on it.
In the meantime, try these steps:
- Go to Dashboard -> Updates
- Press the "Check Again" button
- Press the "Update" button at the bottom of the page
- Try to update the plugins
- Go to Plugins -> Add New -> Commercial
- Press the "Check for updates" button
- Go to https://wpml.org/account/sites/ look for your current key and erase it.
- Create a new one for your site.
- Click on the "Unregister WPML from this site" button
- Register WPML adding your new key.
- Try also disabling the "Keep wpml.org up-to-date about which theme and plugins I use" option
If that does not fix the issue you can manually update the plugins.
- Download the latest version of the plugins that need to be updated from https://wpml.org/account/downloads/
- Disable the outdated ones
- Delete them (the settings and the translations are saved in the database so they will not be deleted)
- Upload the freshly downloaded plugins from Plugins -> Add New -> Upload Plugin
- Activate them
Thank you
February 11, 2019 at 1:52 pm #3183158
arminS-15
This steps finally were able to update the plugins:
=> now try to update the plugins again, this worked for me!
Thanks for the good support!
Best regards, Daniel Scheibe
