Last updated by Bobby 1 year, 9 months ago.
Assigned support staff: Bobby.
October 10, 2019 at 4:29 pm #4732931
jonathanF-3
We would like to prevent unnecessary code from loading at all.
Even if we use : define('ICL_DONT_LOAD_LANGUAGE_SELECTOR_CSS', true);
the flag are still loading (even if not used), see here :
Please confirm how we can prevent those img's to load.
October 11, 2019 at 1:25 am #4734563
Bobby
Hi There,
When you go to WPML->Languages->edit a language switcher and remove the flag in the front end, the flag will not load anymore even if you don't use the above code.
You can check this on the following staging site that is using a default theme (Twenty19).
-> hidden link
The code that is loading the src for the flag is coming from your Theme Jupiter.
Notice the class is "mk-lang-name" which is a Jupiter class.
