Last updated by Bobby 2 months ago.
Assisted by: Bobby.
April 11, 2024 at 6:14 pm #15510756
nicoleM-23
When on the Spanish version of the site, the Previous and Next links on the Events page go to the English version of the site.
LINK to Example: hidden link
April 12, 2024 at 12:50 am #15511135
Bobby
Is this page created using the events calendar plugin?
Try the following steps and let me know your results, please.
1. Go to WPML > String Translation
2. Search for shows-and-events (from "the-events-calendar" textdomain). Translate it
3- Re-save permalinks
April 12, 2024 at 3:39 pm #15513474
nicoleM-23
Hey Bobby,
We are using The Events Calendar, but that string did not appear in the search under any text domain.
April 15, 2024 at 9:15 pm #15521970
Bobby
Thank you,
Bobby
April 16, 2024 at 9:53 pm #15528335
Bobby
How are the events displayed on the page, I can see you are using a template called events, is this a custom template?
April 17, 2024 at 7:16 pm #15534642
nicoleM-23
Yes, the template file is events.php
April 17, 2024 at 7:59 pm #15534760
Bobby
Thank you, for confirming.
Are you the developer of this template file or somebody else in your team.
Please note that support for custom work is outside our scope.
I'll guide you as best I can, but if you need further assistance, consider reaching out to one of our trusted third-party contractors who specialize in custom WPML work.
You can find them here: https://wpml.org/contractors/
when reviewing your template I can see that the pagination is created using next_posts_link() and previous_posts_link()
these do not account for the language parameters.
You might want to review our Hooks documentation, especially wpml_permalink.
https://wpml.org/wpml-hook/wpml_permalink/
April 18, 2024 at 3:19 pm #15539981
nicoleM-23
Our developer is assisting with this issue. She has reviewed the documentation, but it is not very clear.
From her:
The documentation provides one-line examples devoid of context and assumes we know the language code that needs to be output. Given that we're on a template using standard WordPress core functions, we need a solution that accounts for that.
Do I need additional work to establish the language code/directory that is currently active?
April 18, 2024 at 9:32 pm #15541136
Bobby
Thank you for updating us, yes you would need to create additional work and some sort of logic in order to filter for the language code.
At the moment the function that is being used for pagination does not take in account language directories thus this happens, if you do a quick search on that function you will find some other issues with it and directories being ignored.
The standard for linking between posts would be something like:
<!-- Start the pagination functions after the loop. -->
<div class="nav-previous alignleft"><?php next_posts_link( 'Older posts' ); ?></div>
<div class="nav-next alignright"><?php previous_posts_link( 'Newer posts' ); ?></div>
<!-- End the pagination functions after the loop. -->
Source -> https://developer.wordpress.org/themes/functionality/pagination/
This would be numeric pagination for an archive:
echo the_posts_pagination();
Possibly this helps your developer, however, i suggest using a different function for the pagination than next_posts_link()
April 23, 2024 at 7:18 pm #15557874
nicoleM-23
Hey Bobby,
Thanks for clarifying! We'll pass this along to our developer and get back to you if she has any questions.
April 23, 2024 at 11:38 pm #15558467
Bobby
No problem, glad I was able to provide some assistance.
April 25, 2024 at 1:17 pm #15565850
nicoleM-23
Hey Bobby,
Alexis, Nicole's dev, here 🙂
It turns out the issue wasn't in the pagination functions, but the query. There was an additional plugin causing a conflict and altering the URLs.
We've got that resolved now, but wanted to let you know 🙂
April 25, 2024 at 7:40 pm #15567216
Bobby
Hi Alexis,
Thank you for updating us! I am sure this will help others who might face a similar issue in the future.
Glad to hear it is working OK now.
This ticket is now closed. If you're a WPML client and need related help, please open a new support ticket.
