Last updated by Mihai Apetrei 1 year, 7 months ago.
Assigned support staff: Mihai Apetrei.
October 15, 2018 at 9:42 am #2816817
spyridonE
I am getting this message on my WP dashboard:
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Array
[language] => en
[context] => dokan-lite
[gettext_context] =>
[domain_name_context_md5] => 01356a41f6a9a1d26b9c9a3ec235f01e
[name] => 8c1ee449418789460326ef3cb333e2d9
[value] => Dismiss this notice.
[status] => 0
[translation_priority] => optional
[allow_empty_value] =>
October 16, 2018 at 5:19 pm #2821972
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
It is safe to just dismiss that notice as it could be a one-time event due to updates and all should be fine with WPML after you close that notice. We had a similar issue before but it was handled already in the current version.
In the case where you can’t dismiss this notice, you can solve it by removing the empty value from your database table "wp_icl_strings" using database tools like PHPMyAdmin (or similar) or you can simply remove the entry from inside WPML > String Translation.
❌ Before doing that please backup your database and website for safety. ❌
What is practically happening is that the system is trying to insert a value when one already exists in another language tag.
Please let me know if this solved your issue or if you still need help.
Kind regards,
Mihai
October 23, 2018 at 8:13 am #2841375
spyridonE
I deleted the value ([name] => 8c1ee449418789460326ef3cb333e2d9 and [context] => dokan-lite) but I still get the error, how long until WPML stops reporting a problem?
Also note I have multiple rows with the same name (but different context etc). I would guess the system checks more than the name so I don't need to delete them also, right?
October 23, 2018 at 5:40 pm #2843700
Mihai Apetrei
Hi.
Can you please let me know if you also tried to click the "X" to dismiss the notice after you deleted the record from the database and the error appeared again?
Regarding this "Also note I have multiple rows with the same name (but different context etc). I would guess the system checks more than the name so I don't need to delete them also, right?", we won't have anything to do with the other records, just with the one from the error.
Kind regards,
Mihai
October 24, 2018 at 9:09 am #2845513
spyridonE
yes, the notice is dismissed multiple times but the error is appearing again.
Running
SELECT * FROM `wpbi_icl_strings` WHERE name = "8c1ee449418789460326ef3cb333e2d9" AND context = "dokan-lite"
returns 0 rows.
October 24, 2018 at 3:26 pm #2847054
Mihai Apetrei
I see.
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
- Please make a backup of the site files and database before providing us access.
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields. If you do not, please ask me to enable the private box.
The private box looks like this: hidden link
October 25, 2018 at 11:31 am #2849563
spyridonE
Hello and thank you for your help.
The notice is not reappearing anymore. I am not sure why it took time for this to happen (caching maybe?)
In any case, this can be marked as resolved.
thank you again for your assistance.
October 25, 2018 at 2:59 pm #2850196
Mihai Apetrei
Hi.
I am very glad to hear that this doesn't show up anymore.
Yes, it might have been showing due to caching.
I will mark this ticket as resolved then.
Kind regards,
Mihai
