Last updated by Noman 1 year ago.
Assigned support staff: Noman.
April 27, 2019 at 12:25 pm #3695393
martijnR-3
After activating WPML we faced a white area on the left side of the page and we have to scroll to right so we can see the content
We deactivate WPML and the problem disappeared
our website is zad.tv
you can see an example of the issue in the attachment
April 29, 2019 at 10:33 am #3702153
Noman
Thank you for contacting WPML support. Could you please follow below steps and let me know how it goes?
1. I have noticed that your website’s WP Memory Limit is 40MB. The WP memory limit needs to be increased, it's different than php memory. PHP memory is fine but WordPress uses 40Mb as default in your site. Minimum requirements for WPML are 128Mb: https://wpml.org/home/minimum-requirements/
Please add this to the top of wp-config.php to increase WP memory:
/* WP Memory Limit */
define('WP_MEMORY_LIMIT', '512M');
define( 'WP_MAX_MEMORY_LIMIT', '512M' );
2. Please upgrade your server’s PHP version to a higher level: https://wpml.org/home/minimum-requirements/
- PHP is 5.6.36 which is good, but it's advised is to use more up-to-date version for better performance and stability. You can contact your website hosting company to upgrade this for you.
3. Please upgrade your server’s MySQL version to a higher level: https://wpml.org/home/minimum-requirements/
MySQL 5.5.5 version in your site, is lower than the required for WPML.
4. I have noticed that you are using older version ( 3.9.4 ) of Avada theme and latest version of Avada theme is 5.9, please update the theme for better performance and stability.
Thank you
The topic ‘[Closed] Problem for responsive mode in mobile view’ is closed to new replies.
