Last updated by Mihai Apetrei 1 year, 7 months ago.
Assigned support staff: Mihai Apetrei.
October 18, 2018 at 4:52 pm #2828876
jakubK-19
I got an error in tables:
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Array
[language] => en
[context] => admin_texts_woocommerce_failed_order_settings
[gettext_context] =>
[domain_name_context_md5] => dcb832addf87a4eb9f6d3778c8ff0ea6
[name] => [woocommerce_failed_order_settings]subject
[value] =>
[status] => 0
[translation_priority] => optional
[allow_empty_value] => 1
October 19, 2018 at 3:54 pm #2832617
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
It is safe to just dismiss that notice as it could be a one-time event due to updates and all should be fine with WPML after you close that notice. We had a similar issue before but it was handled already in the current version.
❌ Before doing that please backup your database and website for safety. ❌
In the case where you can’t dismiss this notice, you can solve it by removing the empty value from your database table "wp_icl_strings" using database tools like PHPMyAdmin (or similar) or you can simply remove the entry from inside WPML > String Translation.
Please let me know if this solved your issue or if you still need help.
Kind regards,
Mihai
