[Resolved] problem in translating widgets and gravity form
GravityForms strings are not being translated, even if translation is included in the WPML > String Translation.
In this ticket, the problem is that the strings had been incorrectly entered in the language. In WPML > String Translation make sure that the string is registered in the correct language.
You can either delete the wrong strings or update the language of the strings in WPML > String Translation.
In regards to the widget, in your video, you are referring to the wrong widget area. The widget that shows in the drop-down slider is found in the "Sliding Top | #2" widget area. Currently, you only have one version of the Text widget there.
Hi, this url you're checking is not a gravity form but a contact form.
The gravity form is in url : hidden link
please mark as private the url i paste and your previous screenshot.
best regards,
Ricardo is off today. I would like to take care of your ticket from now.
The problem is happening because initially these strings were registered in English even being in Greek. To fix the problem you will need to switch these strings to Greek and then probably translate the form again. At this point, you will need to confirm that you have a backup of your database.
Please, can I install the Adminer plugin to edit these strings inside the database? Basically we will need to run this query:
UPDATE `wp_icl_strings` SET language = 'el' WHERE `context` = 'gravity_form-1'
That way all the strings of Gravity Forms 1 (your form) will be converted to Greek and then this should work correctly.
I understand this, that's strange though, as when i installed wpml i've set that the current data language is in greek.
In string translation i see many strings (maybe twice the strings of the gravity form fields) in both source languages.
When i translate via "Translations queue" the form seems ok. When i visit string translation i see both your screenshot and both the strings in the right order, like the screenshot i'm sending you.
It seems like some strings are in the correct lang and some in the wrong lang.
Some of the strings are twice with same text one as greek and one as english source language.
Is there a way to delete all the strings from gravity_form-1, ask wpml to load the form in translation and translate it from the begining, via "Translations queue" as it's easier ?
I dont care if i should translate it again, just want to get rid of the double strings in order to be easier to change something via string translation at a later time.
If i should run a query i can do it myself (i can make the website offline, take a backup, check and re-translate faster than waiting for your support to run it, as the website is live).
For example when i delete a string from a plugin, i do a re-scan from "theme and plugin localization), in this type of translation that the strings are not in some mo/po files, how can i ask wpml to read and register again the form for translation?
best regards,
Removing the strings and resubmitting the content for translation by following the same steps you did earlier should also work correctly.
If it does not work and for some reason, the strings are still registered in the wrong language, just follow the steps I posted above and then translate the strings again.
In fact, I think the easiest and quickest would be to run the query I posted above, as all content should be displayed in Greek.
About "duplicate" strings, please note that there are two fields types: "label" and "value". That is, although the content is the same, the fields have different purposes. That is, these strings are not duplicated. I'll attach the same images you attached so you can see the difference.
