Last updated by Mihai Apetrei 1 year, 4 months ago.
Assigned support staff: Mihai Apetrei.
October 17, 2018 at 11:37 pm #2826074
Maurizio Facchini
I bought the pro version today and installed it on the website (already online and active) but when I start to configure wpml it remains blocked on language selection. I select the languages that interest me (Italian by default and English) and if I click on save - forward the screen does not go on and therefore I can not complete the activation
the default guide
no
it's a e-commerce with Woocommerce.
October 18, 2018 at 3:57 pm #2828656
Mihai Apetrei
Hi and thank you for contacting WPML Support!
I will be happy to help you with this.
Usually, this is caused by caching plugins that are active while the WPML setup. It can also happen due to server settings.
Disabling Memcache should help if it's used on the site.
Can you please paste your WPML Debug information in the Debug information field?
Kind regards,
Mihai
October 19, 2018 at 10:06 am #2831509
Maurizio Facchini
Hi, I have try to remove cache but the problem is the same.
the strange thing now is that the Italian language (language of my theme and wordpress) is no longer selected, and comuqneu if you select English the Forward / news button does not activate anyway
October 22, 2018 at 1:18 pm #2838197
Mihai Apetrei
Hi.
If this is the first time you are installing WPML and you have no saved translations or important WPML data saved in the database already, let's try a WPML reset first and then a few more steps that might help.
❌ Important: please make a backup of your site (files & database) before following the steps ❌
1. WPML RESET
In order to Reset your website, you need to go into your WordPress Dashboard > WPML > Support > Troubleshooting (there’s a text-link called exactly that) > at the bottom of the page you will find the “Reset” section. Just by checking the “I am about to reset all translation and language data.” check-box and by clicking the “Reset and deactivate WPML” blue button will completely delete all the WPML tables in the database and deactivate the WPML plugin so after doing that, you can start with a fresh new WPML setup and start using the plugin to translate any part of content you like.
2. DELETING CACHE AND DISABLING SG OPTIMIZER
Please go to SG Optimizer > SuperCacher config > Purge the cache + disable Dynamic Caching.
After doing this, also disable the "SG Optimizer" plugin.
3. RETRY WPML SETUP
Now please try to install WPML again and go through the setup.
Think should work properly now.
Please let me know if this solved your issue or if you still need help.
Kind regards,
Mihai
