Last updated by Dennis 11 months, 3 weeks ago.
Assigned support staff: Dennis.
June 7, 2019 at 7:06 am #3974291
alessioL-5
Good morning, I'm working with wpml on a multi-lingual site (Italian and English).
I tried to translate some strings of the administration area containing links but unfortunately even compiling them do not work.
How is this possible?
Attached a screenshot
Greetings Stephen
June 7, 2019 at 9:15 am #3975189
Dennis
Welcome to WPML Support forum.
Could you please increase the WP Memory Limit (your current setting is 40M). Minimum requirements are 128Mb:
/** Memory Limit */
- Add it above the line
Also, I would like to recommend you to increase your max input vars, currently it has a value of 1000 in your WordPress Dashboard > WPML > Support section.
Please, try to increase it to 5000. You might need some assistance from your host to properly set this up.
See:
Then,
-Make a complete backup of your site ( Important! )
-Go to WPML>>Support page
-Click on Troubleshooting link (link in the middle of the page)
-In Troubleshooting page, please click on the following options of 'Clean up' section. Wait for confirmation of processing after each one.
- Clear the cache in WPML
- Fix element_type collation
- Set language information
- Fix terms count
- Fix post type assignment
-Recreate ST DB cache tables
-go to WPML > String Translation and re-save your translations for the strings in question.
Does it help? Please let me know how it goes.
Kind regards,
Dennis
The topic ‘[Closed] Problem translate admin field’ is closed to new replies.
