Last updated by Mihai Apetrei 1 year, 4 months ago.
Assigned support staff: Mihai Apetrei.
March 29, 2019 at 12:26 pm #3491171
Mihai Apetrei
Hi.
I totally understand that.
My guess is that this is a compatibility issue so because we have it recreated in the sandbox, I will be able to send it forward to my colleagues from another department and see what they say.
I will leave this ticket assigned to me for the moment.
Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week with new feedback regarding this.
Kind regards,
Mihai
April 1, 2019 at 8:51 am #3505413
Mihai Apetrei
Hi and thank you for your patience.
I wanted to let you know that I escalated this to our Compatibility department and I am currently waiting for an answer from the team.
I will also change the status of this ticket to "Escalated to Compatibility team" and I will keep you updated as soon as I have any feedback.
Kind regards,
Mihai
April 5, 2019 at 7:47 am #3541639
Mihai Apetrei
The Compatibility department responded back and it seems that I was doing a mistake as I did not realize that on the sandbox testing environment, the theme that was active was the child theme so that is why I was not able to find the strings.
It seems that I was able to find it after I realized that.
I will also attach some screenshots so that you can take a look at what I did and you can also check that on the sandbox backend.
Instead of looking at "theme_mods_oceanwp", we need to look at "theme_mods_oceanwp-child-theme-master".
So things work properly on a clean install and they should work for you, too, on your site.
If they still don't work, I suggest that you follow the next steps here:
- disable all plugins except WPML and its add-ons + Ocean WP Extra that enabled the functionality
- check if the issue is happening again
- if it's not, reactivate your plugins one by one, checking every time if the issue shows up again so that you can understand which plugin is causing that issue
If the issue happens even with the non-WPML plugins disabled:
- leave all the non-WPML plugins deactivated
- switch to a the main oceanwp theme (change from child to main)
- now you will need to be concentrating on the "theme_mods_oceanwp" admin texts so test if it's working with that. If it does, there might be something wrong with the child theme
Please let me know how it goes and what you will be able to find.
Just a note that I won't be working on the weekend so I will be able to get back to you at the beginning of next week.
Kind regards,
Mihai
