Last updated by Andrés 1 year, 7 months ago.
Assigned support staff: Andrés.
October 13, 2018 at 2:44 pm #2814281
Adriano
Ciao Andrés,
every so often I get the following message in the wordpress dashboard:
We have detected a problem with some tables in the database. Please contact WPML support to get this fixed.
Array
    [language] => it
    [context] => admin_texts_woocommerce_new_order_settings
    [gettext_context] =>
    [domain_name_context_md5] => d3218db82312465bbeae3d2ebc6a624f
    [name] => [woocommerce_new_order_settings]heading
    [value] => Nuovo ordine cliente
    [status] => 0
    [translation_priority] => optional
    [allow_empty_value] => 1
What should I do?
Grazie,
Adriano
October 13, 2018 at 4:15 pm #2814336
Andrés
Languages: English (English ) Spanish (Español ) French (Français )
Timezone: Europe/Paris (GMT+02:00)
Hola Adriano,
¿Trabajando de nuevo durante los fines de semana? 🙂
Many of the times, this alert is just a false positive and you shouldn't take care of it. For being sure about it:
1. Open your wp-config.php file and look for define(‘WP_DEBUG’, false);. Change it to or just add it:
define('WP_DEBUG', true);
In this case the errors will be saved to a debug.log log file inside the /wp-content/directory and look for any PHP error related to WPML.
2. If it is not the case, just follow the errata and close the warning:
https://wpml.org/errata/duplicate-entry-for-key-uc_domain_name_context_md5/
Does it help?
Un saludo,
Andrés
October 15, 2018 at 1:24 pm #2817685
Adriano
Ciao Andrés,
you also work on Saturdays ? in addition to Saturday, sometimes I also work on Sundays.
At the moment the error is no longer displayed, so I do not know whether to worry or not. In the link that you kindly gave me George writes that it is a very serious problem and that it should have been corrected with WPML 4.0.6:
https://wpml.org/errata/duplicate-entry-for-key-uc_domain_name_context_md5/#comment-1846784
but now I have version 4.0.7 and the problem reoccurs.
Un saluto,
Adriano
October 15, 2018 at 1:59 pm #2817884
Andrés
Ciao Adriano,
Yes, there late days have been pretty busy, but soon I'll take some vacations.
I'm glad to know that the message has disappeared. Now, about George's comment, you are totally right but there is a difference, that user is mentioning a duplicate of a Primary key which points to a database corruption while is not the case:
Duplicate entry ‘0’ for key ‘PRIMARY’
Does it answer your question?
Andrés
October 19, 2018 at 2:48 pm #2832439
Adriano
Ciao Andrés,
now the problem is gone, I hope it will not be repeated in the future.
Saluti,
Adriano
October 19, 2018 at 2:54 pm #2832477
Andrés
Awesome, Adriano! 🙂
Ora per godersi il weekend.
Chao!
