Related documentation:
This topic contains 44 replies, has 2 voices.
Last updated by przemyslawP-15 6 months, 3 weeks ago.
October 27, 2021 at 10:17 am #9872669 | |
przemyslawP-15 |
I've checked one more time your site and you have not filled in the fields that cause the error. Please have a look, on your site the issue still exists too |
October 27, 2021 at 10:19 am #9872671 | |
Alejandro Supporter
Languages: English (English ) Spanish (Español ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Hm, at this point can i have access to a staging site without the changes made so i can apply the changes there and check what's going on by comparing it with the sandbox? I have enabled the credential fields so you can add them privately. |
October 27, 2021 at 10:37 am #9872851 | |
przemyslawP-15 |
Now there is identical situation on my and your page, the same issue, the same line. |
October 27, 2021 at 11:03 am #9873097 | |
Alejandro Supporter
Did you do or touched something in the sandbox? the notification was gone when i tested it and i suspect at this point that maybe the problem returns if something is resaved or similar. did you change or resaved any option, retranslated or deleted something in the sandbox? |
October 27, 2021 at 11:58 am #9873419 | |
przemyslawP-15 |
Yes, I filled in the fields that cause the error (of the repeat fields type). I don't know why, but they were empty. I'm sure I completed them before when you asked me to recreate the issue. You didn't see the error because the fields in the block did not contain any content. |
October 27, 2021 at 12:21 pm #9873589 | |
Alejandro Supporter
Perfect. i'll go check then with our developers about this. I'll keep ypu updated (please do not answer this ticket yet). |
October 27, 2021 at 1:17 pm #9874357 | |
Alejandro Supporter
Ok, i think that we're not on the same page here. i recreated the case in a different sandbox: hidden link and in there i can't see the error, however i filled and created repeater elements in all the footer block. could it be that the content you were talking about needed to be filled in somewhere else? |
October 28, 2021 at 6:23 am #9879275 | |
przemyslawP-15 |
What's the difference which sandbox is it? You asked me to recreate issue on your sandbox and I did it, you could see it. By the way I checked your second sandbox and you had debugging disabled (define( 'WP_DEBUG', false );). I changed it for 'true' and now you can see the same issue. |
October 28, 2021 at 7:30 am #9879811 | |
Alejandro Supporter
the debug was set to true afterwards ( i saw it was defined twice) but i believe the problem with the error not appearing is on our end, these sandboxes might have cache or something because after a while they appear and for this i can only apologize. Our developer could actually see the problem before and was working on it. |
November 2, 2021 at 7:51 am #9905993 | |
Alejandro Supporter
Can you please change the code i gave you before with this one: private function get_string_hash($block_name, $text) { if (is_array($text)) { $result = ""; foreach($text as $t) { if (is_array($t)) { $result .= implode($t); } else { $result .= $t; } } } if (isset($result)) { $text = $result; } return md5($block_name . $text); } you can see the entire procedure here: https://wpml.org/forums/topic/problem-with-acfml/page/2/#post-9866207 Let me know if that works for you. |
November 2, 2021 at 8:10 am #9906085 | |
przemyslawP-15 |
Hi, Fatal error: Cannot redeclare WPML_ACF_Blocks::get_string_hash() in /home/laboprint/web/public/pub/wp-content/plugins/acfml/classes/class-wpml-acf-blocks.php on line 148 |
November 2, 2021 at 2:47 pm #9910329 | |
Alejandro Supporter
that error there means that the function already exists somewhere in the file and that should not happen, there should only be 1 function like that. can you please delete ACFML, download a fresh copy, install it and change the old function ( get_string_hash() ) with the new that i gave you? |
November 3, 2021 at 8:41 am #9914579 | |
przemyslawP-15 |
Hi, Bes regards |
November 3, 2021 at 3:26 pm #9918341 | |
Alejandro Supporter
It will be included in the next release of ACFML among a few other improvements. I apologize if i wasn't clear enough before, but i'm glad it's working now. |
November 4, 2021 at 7:07 am #9922343 | |
przemyslawP-15 |
My issue is resolved now. Thank you! |
