When i go to : wpml->string translation->Translate texts in admin screens and select an option of the theme and click apply, i cannot then find it in string translation.
When i go again to wpml->string translation->Translate texts in admin screens i still see the option unchecked.
You need to register this string using WPML-config XML code. You can add the XML code on WPML > Settings > Custom XML Configuration.
In this case, the client needed to register the string located in organics_options->contact_info. So we registered it using this XML code:
<wpml-config>
  <admin-texts>
    <key name="organics_options">
      <key name="contact_info"/>
    </key>
  </admin-texts>
</wpml-config>
You can read more about the WPML XML config here: https://wpml.org/documentation/support/language-configuration-files/
Relevant Documentation:
Last updated by Diego Pereira 2 years, 7 months ago.
Assigned support staff: Diego Pereira.
July 18, 2018 at 3:00 pm
The Smalls
hi, when i go to : wpml->string translation->Translate texts in admin screens and select an option of the theme and click apply, i cannot then find it in string translation.
When i go again to wpml->string translation->Translate texts in admin screens i see the option unchecked
my theme is organics and the option i'm trying to translate is :
organics_options->contact_info (value : Ορθοκυτταρικά Συμπληρώματα Διατροφής)
best regards,
July 19, 2018 at 1:16 pm #2534826
Diego Pereira
Please add this XML code snippet to WPML > Settings > Custom XML Configuration:
<wpml-config>
  <admin-texts>
    </key>
  </admin-texts>
</wpml-config>
Now the string should be displayed on the String Translator.
Documentation link: https://wpml.org/documentation/support/language-configuration-files/
Please let me know if it worked for you.
Diego
July 19, 2018 at 1:24 pm #2534836
The Smalls
that worked.
best regards,
July 19, 2018 at 1:26 pm #2534841
Diego Pereira
Hi there, I'm glad to hear that the issue is solved ?
Please contact us if you need our help in the future with WPML. We will be more than happy to help.
Cheers,
Diego
