Last updated by Laura 8 months, 2 weeks ago.
September 9, 2019 at 8:34 am
olivierF-6
I have a a form to edit a repetable group of fields.
The form works very well when I'm on the French page but when I'm on the English page, I can not select the post to add the repetable field group. The select is grayed out (see capture). I use wpml for traduct page and Toolset for create CRED form.
The custom post type is not translatable in the wpml options and it should not be, it's the same post in French and English. But I must be able to translate the form ...
I also tested by creating posts in English but the selection is still unavailable, why?
Here is the code I use to display the selector...
[cred_field field='@collaborateur-projet.parent' class='form-control' select_text='--- non défini ---' author='$current' order='date']
September 9, 2019 at 9:47 am
September 13, 2019 at 9:43 am #4567137
olivierF-6
Can I have a follow up to my request?
Thanks in advance
September 13, 2019 at 1:51 pm
The topic ‘[Closed] Problem with cred form and repetable group of fields’ is closed to new replies.
