Last updated by Shekhar Bhandari 9 months, 3 weeks ago.
August 12, 2019 at 7:13 pm #4383355
t.j.P
We're having some issues with custom fields on certain pages.
We have an external company in charge of the localization of the site, and they are implementing it using Memsource as a translation manager. Memsource is directly connected to WPML, and most of the translation jobs went smooth.
But in some cases, custom fields are not being populated at all despite being sent from Memsource to WPML. We already checked on the Custom Fields Translation options section, and those fields are set as "translate". Even when we manually go to edit those pages using the WPML's Translation editor, those fields appear there available.
You can review these two pages as example:
EN => hidden link
FR => hidden link
August 13, 2019 at 8:47 am #4385967
Shekhar Bhandari
Hello there,
Welcome to WPML support. I'd be assisting you further on this issue.
So the fields are marked as translate and translated but not displaying correctly, right? Are you talking about the sidebars?
Can you check if the fields are set properly as explained here: https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
If they are repeater fields or such you can view the following steps: hidden link
Let me know if this helps.
The topic ‘[Closed] Problem with Custom fields on ACF’ is closed to new replies.
