Problem: The calendar of'The Events Calendar' by 'Modern Tribe, Inc. is not changing the language (days and months names) when changing the language with the Language Switcher. Solution: 'The Events Calendar' is not officially compatible with WPML. Nevertheless, unchecking the 'Enable the Month View Cache' option in the plugins settings Events -> Settings -> Display (tab) solved this problem.
0% of people find this useful.
This topic contains 10 replies, has 3 voices.
Last updated by Itamar 1 year, 10 months ago.
July 10, 2017 at 1:41 pm #1315818 | |
georgeA-5 |
Hello, From what I came up to after searching, the problem had been mentioned by other users too.. When switching months at a calendar, the languages are getting mixed up. Is there any solution for this issue? Thanks |
July 10, 2017 at 4:58 pm #1316034 | |
Itamar Supporter
Languages: English (English ) Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+02:00) |
Hello. Thank you for contacting the WPML support forum. Are you referring to 'The Events Calendar' by 'Modern Tribe, Inc.'? Thanks, |
July 11, 2017 at 7:47 am #1316404 | |
georgeA-5 |
Hi Itamar, Yes, that is the plugin I am talking about. This is another question I found in the forum To be more specific about the issue I was talking about, even if I am on the english page I see the calendar in Greek (image en1) and when I click the previous or next month buttons at the bottom, it redirects to the greek page of calendar. (image en2) |
July 11, 2017 at 7:04 pm #1317170 | |
Itamar Supporter
Hi. When I'm checking your site now I can see that in the first time that I visit the seminars' page the calendar shows fine; it is in English. Thanks, |
July 12, 2017 at 3:03 pm #1317940 | |
georgeA-5 |
Hi! The steps you suggested, fixed the issue with the pagination of the months. But the problem is now that when I am in the calendar page and I hit the other language button on the top right corner (for example, when I am at the greek calendar and I click the EN button), the language of the calendar is not changing. |
July 12, 2017 at 6:32 pm #1318169 | |
Itamar Supporter
I've installed this plugin on my local server and tested the issue. Thanks, |
July 13, 2017 at 8:26 am #1318460 | |
georgeA-5 |
Hi Itamar. Yes, this fix seems to have solved the problem. Thanks |
July 13, 2017 at 9:44 pm #1319227 | |
Itamar Supporter
OK, @georgea-5, let's hope for the best 🙂 |
October 6, 2017 at 2:24 pm #1393759 | |
georgeA-5 |
Hello, I am coming back to this problem as it started happening again. I searched about it a little bit and run into this: I realized that this happens if I am logged in the site. So the question is if there is anything that we can do to make it work in both circumstances. Thank you |
April 11, 2019 at 4:37 pm #3590705 | |
nickP-2 |
Hi, i am facing the same issue here. i tried the above solution but nothing seemed to work. Any other suggestions? Thanks |
April 11, 2019 at 8:00 pm #3592517 | |
Itamar Supporter
Hi. This is an old ticket, and things might have changed. Please open a new ticket in our forum and add all the relevant information about the issue that you are having. Regards, |
