Last updated by Carlos Rojas 1 year, 9 months ago.
August 6, 2018 at 11:01 am #2615550
maratC
Greetings!
I have another issue with WPML plugin.
There is a problem with Features translation on every single property page. As a matter of fact, I have translated them all in every language I need. But for some reason, an only in this part of property page, it is not translated. So that in every language there is only french text. How can I fix that?
Marat
August 6, 2018 at 7:01 pm #2617146
Carlos Rojas
1.- I'm sorry but I can't see the issue you are referring to. Could you attach some screenshots in your next message and highlight the features that doesn't show translated?
2.- Please provide the debug information of the site. In this link you will find the steps to follow: https://wpml.org/faq/provide-debug-information-faster-support/
Kind regards,
Carlos
August 14, 2018 at 9:17 am #2642804
maratC
Greetings!
Sorry for not replying before... I am dealing with several issues at the same time....
Look, if you will click on any object for example this one
ans scroll down, you will see there is a features box...
So in every language it displays only french language text in this box.
August 14, 2018 at 5:55 pm #2644207
Carlos Rojas
In this case you should be able to translate this custom fields by going to WPML -> Settings -> Custom Fields Translation (you may need to click on 'Show system fields') -> Set the fields to 'Translate' -> Save the changes.
Then translate the posts again.
Could you tell me the result of the steps above?
Carlos
August 20, 2018 at 11:34 am #2659140
maratC
Greetings!
Those fields (all kind of features fields) have been already set to Translate long time ago.
So apparently this solution doesn't help. If you want, I can give my access details, so that you could have a look inside the admin panel of my WP site.
Marat
August 20, 2018 at 5:39 pm #2660436
Carlos Rojas
Hi Marat,
Our Debugging Procedures
Carlos
August 22, 2018 at 5:42 pm #2667600
Carlos Rojas
Hi Marat,
Thank you very much for the informatino provided.
However I will need access to the backend of the site (wp-admin). I have your next answer private again so you can provide the necessary credentials.
Looking forward to your answer.
Carlos
August 22, 2018 at 7:15 pm #2667871
Carlos Rojas
Hi Marat,
I would like to ask you to follow this steps:
- Go to Properties -> Features -> Translate all untranslated features to all languages.
- Go to Properties -> Translate the properties to all languages.
- Go to WPML -> Support -> Troubleshooting link -> Click on 'Clear the cache in WPML' button.
- Flush all cache memory that might exists.
Could you tell me if the issue persists after the steps above?
Carlos
August 23, 2018 at 7:50 am #2668983
maratC
Greetings!
So I have tried to translate a property, not all of them, cause there are more than 6000... Apparently, the problem lies there. Only translated properties will have these features translated.
Now, I have a few questions...
1. Is there a way to pur the features text in Strings list, so that they could be translated as strings?
2. Will the translation of all properties cause their duplication? I mean, in terms of disc space, will cause a drastic effect?
3. Is there a way to translate all the properties in bulk?
Marat
August 23, 2018 at 3:50 pm #2670802
Carlos Rojas
Hi Marat,
1.- No, taxonomies have their own section to be translated. In this link you will find more information about taxonomy translation: https://wpml.org/documentation/getting-started-guide/translating-post-categories-and-custom-taxonomies/
2.- No, the taxonomies will only be translated once and the referenced by all the posts. That's why, when you are translating a post with the Translation Editor there is a warning message in the taxonomy section.
3.- It is possible to 'copy' the taxonomy terms to all languages but not translated them in bulk.
Please let me know if you need further assistance and I will be more than happy to help.
Carlos
