Last updated by srdjan 6 years, 12 months ago.
Assigned support staff: srdjan.
January 20, 2015 at 7:40 am #545497
Dorian
I am using the Jetpack plugin (latest version), mostly to take advantage of its "related posts" function (since my webhost doesn't allow the use of many other related posts plugins).
While the function works great with the English version of my site, it doesn't appear on the Chinese version. I wonder whether this could be caused by URL format I'm using? A "/zh/" directory is necessary for all Chinese pages to display, while the English version doesn't need such a directory. (see screenshot)
Thanks in advance for your help.
Best,
DC
January 20, 2015 at 1:21 pm #545790
srdjan
Hi Dorian,
are you using some additional plugin to display Related Posts (from list looks like not)?
We need to re-create similar case to check if bug can be reproduced.
I'll update you soon about it.
January 20, 2015 at 4:11 pm #545944
Dorian
The only plugin I'm using for related posts is Jetpack...
No other ones are installed.
Please let me know what you can find.
Best,
D_
January 28, 2015 at 11:52 am #550246
Dorian
Hi Srdjan,
Any luck on this issue yet?
Let me know if I can provide any help.
Cheers
February 2, 2015 at 11:57 am #552678
srdjan
Hi Dorian,
sorry for late reply. We found few issues with Jetpack and merging them together. We're in progress of resolving known issues. I'll update here soon.
February 2, 2015 at 1:55 pm #552779
Dorian
Hi Srdjan,
Actually the issue seems resolved now. I have no idea why, but well, I'm hoping it will stay that way!
Thanks for your help.
Best,
Dorian
February 2, 2015 at 3:30 pm #552907
srdjan
Thanks for update. If you remember anything that may affected it's behaviour - please let me know (because we managed to replicate issue).
