This topic contains 19 replies, has 2 voices.
Last updated by Carlos Rojas 8 months, 4 weeks ago.
August 19, 2019 at 6:46 am #4413775
Carlos Rojas
These are not problems with String Translation. This errors means that there is a plugins or the theme who is changing the default configuration for the custom fields specified in the error message.
Please deactivate all plugins and check if the errors disappeared. If the error disappeared then start activating the plugins one by one until the error appears again. Once you find who is the culprit then you can leave it deactivated during the tests.
Carlos
August 19, 2019 at 6:52 am #4413835
yazanA-2
Hallo , i have already deactivate all plugins , the Errors stay , if you have any solution you can do it , this website is for test , it,s not important if some thing going bad .
August 19, 2019 at 10:05 am #4415031
Carlos Rojas
I applied several troubleshooting steps to the site but the issues persists. I suspect that the cause of this problem is in the database. I will consult our specialists about this issues and I will get back to you as soon as I have an answer.
Carlos
August 22, 2019 at 12:29 pm #4439249
Carlos Rojas
I have escalated this ticket to our compatibility team where our compatibility specialists will take a deeper look at the issue and will try to find a solution.
Thank you very much for your patience and understanding!
Carlos
September 9, 2019 at 8:59 am #4534889
Carlos Rojas
Our specialists took a deeper look at this issue and it seems that the problem was caused in the server side of the Klarna service as they were able to follow the checkout without issues (see attached images).
Carlos
