Last updated by Bruno Kos 1 year, 4 months ago.
May 20, 2020 at 12:57 pm #6177901
assafD
Hello.
After update of the plugin to the latest version and translating Ultimate WooCommerce Auction Plugin with your help. as we spoke I update the WPML and localization the new plugin and start translating it.
Since then the website start throwing me an 500 error.
From my hosting provider I had the info that there is a problem i with the languages and the plugin write new rules in my
public_html/.htaccess. :
Those are the wrong one:
RewriteEngine On
RewriteBase /en/
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /en/index.php [L]
Those should be the right one:
RewriteEngine On
RewriteBase /
RewriteRule . /index.php [L]
So as you can see the difference is in "RewriteBase" rule.
Is there anything that I can do whith your plugin to stop doing this.
We have WPML on our Demo website, which is not updated an it all works fine.
Thanks you
Galya
May 20, 2020 at 1:04 pm #6177969
Bruno Kos
You are probably experiencing this:
https://wpml.org/errata/htaccess-is-rewritten-with-language-folder/
It is not WPML plugin doing this, but some other plugin in combination with WPML.
Can you please try a workaround as defined on the above url or check if this issue appears when:
- only WPML plugins are activated, as it will tell us if there is an interaction issue with other plugin
- theme is set to a WordPress default like Twenty Nineteen as it will tell us if there is an interaction issue with your theme
That would help narrow down which plugin is causing this.
Bruno Kos
The topic ‘[Closed] Problem with languages and htaccess file’ is closed to new replies.
