Our next available supporter will start replying to tickets in about 1.44 hours from now. Thank you for your understanding.
Last updated by Bruno Kos 1 year, 1 month ago.
Assigned support staff: Bruno Kos.
March 28, 2019 at 3:32 pm #3483233
edoardoG-2
I think there are several bugs that affect the latest version of wpml on a multisite network.
for example the media are duplicated, even if I have disabled this option, not only after the reset I lose some media that are corrupted or disappear, or I find myself with 3/4 copies of the same image.
I'm doing a lot of bad figures with my clients.
I use wpml because I find it to be a great product but in the last version it created problems and delays for me
March 29, 2019 at 1:45 pm #3491803
Bruno Kos
When you say this:
Does it mean that you've disabled all the options within:
WPML -> Settings -> Media Translation -> How to handle media for new content:
But if you upload it into media library language, it is available within all languages, or?
Bruno Kos
April 1, 2019 at 5:37 am #3503915
edoardoG-2
the images are corrupted a few times after the uninstallation and installation of wpml and are loaded for all languages
April 1, 2019 at 8:00 am #3505133
Bruno Kos
That would be expected behavior because removing WPML would not delete images upload through various languages.
https://wpml.org/forums/topic/need-to-remove-duplicate-images-from-media-library-after-deactivation-of-wpml/#post-1300146
Can you provide more information on how are these corrupted?
Bruno Kos
April 5, 2019 at 7:23 am #3541257
edoardoG-2
by corrupt I mean that in the library nothing is seen in the preview and by opening it the image is not loaded.
April 5, 2019 at 9:23 am #3542587
Bruno Kos
When does this occur? Does it also happen if:
- WPML and all its addons are not active
- you upload image through page translations when WPML
- you upload images into media library or translations when WPML is not active
If this happens only with WPML, can you test also this way:
- when only WPML plugins are activated, as it will tell us if there is an interaction issue with other plugin
- theme is set to a WordPress default like Twenty Seventeen as it will tell us if there is an interaction issue with your theme
So what I am trying to determine here is what might be the exact culprit for this. Also, note that there have been WPML plugin upgrades since we started this ticket - can you update these all and check then?
Bruno Kos
The topic ‘[Closed] Problem with media’ is closed to new replies.
