Last updated by Jamal 9 months, 3 weeks ago.
August 7, 2019 at 11:17 am #4354223
lisa-annP-2
I am trying to: Get the menu cart to show on two languages
Link to a page where the issue can be seen: The website after adding something to a cart
I expected to see: The cart on English
Instead, I got: The cart only visible on German
August 7, 2019 at 11:20 am #4354231
lisa-annP-2
Let me elaborate a bit more.
I'm using WooCommerce Menu Cart (do you know another plugin that's compatible with WPML?) to display the menu cart once something's been added to it. In german it works - in English it doesn't. The problem is that I can only add one menu to display it, in this case, I've chosen german. I do not want to buy the PRO Version for this only... it will be a huge cost for my customer which I can not justify with the little advantage it comes with. I hope you do have a solution for this! Thanks.
August 7, 2019 at 3:54 pm #4356599
Jamal
I have checked the website hidden link and I was able to add a product to the cart and view it in both languages. Check the attached image for the cart in both languages.
Maybe I did not understand the issue clearly, can you elaborate a little more.
Can you please paste your WPML Debug information in the Debug information field?
- http://wpml.org/faq/provide-debug-information-faster-support/
Jamal
WPML Support
August 8, 2019 at 8:35 am #4361001
lisa-annP-2
it might've been a caching issue... sorry for the trouble. I might come back to you if not everything is clear. Thanks!
August 8, 2019 at 8:35 am #4361005
lisa-annP-2
August 8, 2019 at 9:30 am #4361477
lisa-annP-2
Sorry, I have checked it again, the Cart-Icon is not visible when going back to English. hidden link
Thank you for further investigation.
August 8, 2019 at 11:47 am #4362317
Jamal
I cannot actually suggest another plugin that can offer this feature. You can search for compatible plugins here https://wpml.org/documentation/plugins-compatibility/
But if you manage to reproduce the issue on one of our servers, I'll be happy to escalate it to our compatibility team for a fix. Please use the following link to log in. Configure WPMl similarly to your website and check if the cart disappears in English.
Jamal
The topic ‘[Closed] Problem with menu cart on two languages’ is closed to new replies.
