Problem: I have problem with your WPML menu, in the mobile device part do not give the possibility to change language. is it possible to correct this?
Solution: In order to solve this issue I recommend you to follow this steps: - Go to Appearance -> Menus -> Create a new menu only for mobile - Go to WPML -> Languages -> Menu language switcher -> Create a new language switcher for the mobile menu -> Set this language switcher as a list (not as a dropdown) -> Uncheck the 'Current language' option -> Save the changes.
With this new approach you only need to adjust the flags using CSS (I can help you with this) and the issue will be solved.
Relevant Documentation: https://wpml.org/documentation/getting-started-guide/language-setup/language-switcher-options/
Last updated by Carlos Rojas 1 year, 10 months ago.
September 26, 2018 at 4:10 pm #2768046
gabrieleS-15
the site is: hidden link
I beg you to check with mobile device (iphone or android)
September 27, 2018 at 9:18 pm #2771814
Carlos Rojas
1.- I would like to request temporary access (wp-admin and FTP) to your site to take better look at the issue. You will find the needed fields for this below the comment area when you log in to leave your next reply. The information you will enter is private which means only you and I can see and have access to it.
Our Debugging Procedures
2.- Please increase the PHP Memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
/** Memory Limit */
Kind regards,
Carlos
September 28, 2018 at 5:07 pm #2774498
Carlos Rojas
I wasn't able to log in the site. Could you tell me if you can log in the site correctly? Also, is there any access restriction for the backend of the site?
Carlos
October 2, 2018 at 6:20 am #2780430
gabrieleS-15
no there is no limitation
October 2, 2018 at 4:18 pm #2782249
Carlos Rojas
Unfortunately I can't log in the site, I get an 'ERR_SSL_PROTOCOL_ERROR' message in the browser. Could you double check if everything is working correctly?
Carlos
October 4, 2018 at 10:33 am #2787168
gabrieleS-15
I apologize to you but we have had problems with our VPS, now the website in question has been re-instated and you can connect using these new parameters:
Connect in BO Site
Link: hidden link
User: ***
Password: ***
Connect in Our Server VPS :
User: ***
Password: ***
after entering you have to go to the Captain Deepesh section and enter them in the File Manager of the site and always in that section you can enter even if you need it in the MySql of the site.
I remind you that on the mobile mode (smartphone and tablet) the choice of the multilingual flag is not activated or there is an error.
October 4, 2018 at 5:45 pm #2788438
Carlos Rojas
1.- I have removed the login information from your previous message for ecurity reasons (it wasn't provided in a secure way).
2.- In order to solve this issue I recommend you to follow this steps:
Please let me know if you need further assistance and I will be more than happy to help.
Carlos
October 8, 2018 at 6:14 am #2794805
gabrieleS-15
October 8, 2018 at 3:37 pm #2796768
Carlos Rojas
I'm glad to hear that the issue is solved 🙂
Please don't hesitate to contact us if you need our help in the future with WPML. We will be more than happy to help.
Carlos
