Last updated by Yvette 1 year, 4 months ago.
October 25, 2018 at 8:21 am #2848947
paulL-31
I'm doing the translation of the website under hidden link - after I'm pressing the "polish" button, the menu gets crazy. Please see attached screenshot as a reference.
TOP image original - English
BOTTOM image broken menu - polish.
We are using BeTheme.
Thanks for your help in advance,
Adrian
October 25, 2018 at 12:38 pm #2849753
Yvette
Hello
Before I start to troubleshoot this - could you please increase the amount of PHP memory allocated to your WordPress as required for normal functioning of the plugin.
This means adding this line to your wp-config.php file
Then,
- please go to WPML -> Support -> Troubleshooting > Clean up
- select the option to "Clear the cache in WPML"
Then write back with access to your site (wp-admin) if the problem is still present. I am enabling the private area for username/password of a temp user with admin priveleges.
October 25, 2018 at 12:55 pm #2849859
Yvette
Please re-check the credentials. When I cut&paste them into the logon screen, the system will not accept them.
October 25, 2018 at 1:00 pm #2849862
paulL-31
Please try now.
October 25, 2018 at 1:34 pm #2849953
paulL-31
The details are working for you now?
October 25, 2018 at 5:06 pm #2850565
Yvette
Yes they are - thank you
October 25, 2018 at 5:20 pm #2850593
Yvette
The reason for the disconfigured menu in other languages is due to the custom CSS that you have included which is only targeting the "en" language.
To fix this I replaced your CSS from this:
li#menu-item-wpml-ls-7-en {
    left: 200px !important;
to this
.wpml-ls-current-language {
and it seems to now resolve your styling issue.
October 26, 2018 at 5:38 am #2851995
paulL-31
October 26, 2018 at 6:02 am #2852006
paulL-31
I cannot find the way, how to make a background of the wpml button blue on mobile only, is always changing on the desktop and mobile and also I wish align it to center and make next to it "+" symbol. Is the thing you can help me out as well?
Thank you. 🙂
New threads created by Yvette and linked to this one are listed below:
https://wpml.org/forums/topic/split-css-questions-on-wpml-button/
October 26, 2018 at 6:59 am #2852080
Yvette
I can take a look but as it is not related to the original issue, I have split it into a new forum thread. We can close this ticket definitively now.
