Last updated by Laura 4 years, 10 months ago.
Assisted by: Laura.
June 3, 2019 at 10:05 am #3941173 | |
alessioD-3 |
I Use wpml with multiple domains configuration, the problem is that all admin ajax from domain en language to domain main language return 403 Forbidden error I attached screen |
June 3, 2019 at 2:53 pm #3943713 | |
Laura Supporter
Languages: English (English ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
Hi, thanks for contacting us. I don't have enough information to solve your issue. I would need your WPML debug information. You can find it in: Are you sure you correctly configured the DNS? Did you check our documentation? https://wpml.org/2016/04/use-wpml-different-domains-per-language/ |
June 12, 2019 at 2:35 pm #4005365 | |
alessioD-3 |
I added debug information |
June 12, 2019 at 2:36 pm #4005369 | |
alessioD-3 |
Access to fetch at 'hidden link' from origin 'hidden link' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: It does not have HTTP ok status. Access to XMLHttpRequest at 'hidden link' (redirected from 'hidden link') from origin 'hidden link' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: Redirect is not allowed for a preflight request. |
June 12, 2019 at 2:59 pm #4005577 | |
Laura Supporter
Hi, from your last message, it seems CORS is not configured properly, but this isn't directly related to WPML. I see you have W3 Total Cache, it might be some setting there. Please look at this ticket: https://wpml.org/forums/topic/cors-policy-preventing-copying-content/ the user had a similar issue and it was this plugin. Let me know if this helps you or if you need further assistance. |
June 12, 2019 at 3:44 pm #4005875 | |
alessioD-3 |
I tried solution but not solved, |
June 13, 2019 at 7:03 am #4009741 | |
Laura Supporter
Hi, what did you try? As I said, this is not related to WPML, I'd suggest you reach your hosting for advice on how to fix this. |
June 13, 2019 at 7:34 am #4010189 | |
alessioD-3 |
I verified that disable w3totalcache is solved, thank you for support |
June 13, 2019 at 10:12 am #4011679 | |
Laura Supporter
Glad to hear that, please contact us again if you still need help. |
